Lift for PC 890 - Router Forums
post #1 of 8 (permalink) Old 01-14-2011, 09:47 AM Thread Starter
Default Lift for PC 890
I just built a router table and bought a Rockler top for it. I'll install my PC 890 fixed base. I never used a table before and don't know how hard/easy it will be to make adjustments to an upside down router.
So, do I need a lift? If so, which one? I'm a weekend woodworker and I make lots scrap wood - mistakes that is.
BTW, I did a search and it seems that lift requirements are router specific, so I thought I'd post this.
wsommariva is offline
post #2 of 8 (permalink) Old 01-14-2011, 10:20 AM
Ralph Barker's Avatar
First Name: Ralph
On my previous table I had a 2 1/4hp older Rockwell router mounted in a plain plate. Most of the time, I found it more convenient to lift the plate and router out of the table to make adjustments, change bits, etc. The plate had two 1/4-20 tapped holes near the edge, so I just kept a couple of cap screws with fender washers attached to the heads handy.
When I switched to a heavier 7518 for the new table, I went with the Benchdog Pro lift, which is designed for the 7518. Optional adapter mounts are available for other routers, though.
Bench Dog 40-150 ProLift Router Adjustment System - Rockler Woodworking Tools
- Ralph
Ralph Barker is offline
post #3 of 8 (permalink) Old 01-14-2011, 01:53 PM Thread Starter
I saw that on the Rockler site. Pricey. I'll use my set-up without a lift and if I decide I need one I'll buy it.
Thank you.
post #4 of 8 (permalink) Old 01-14-2011, 02:25 PM
Hi
Many of the Porter Cable routers don't need a add on lift kit ,it's built in on many of them, just need to pickup the right tool for it..
Amazon.com: Porter-Cable 8901 Fixed Base for 890 Series Router: Home Improvement
http://www.amazon.com/Porter-Cable-7..._bxgy_hi_img_b
post #5 of 8 (permalink) Old 01-14-2011, 02:55 PM Thread Starter
That is great...inexpensive. Thank you very much
post #6 of 8 (permalink) Old 01-14-2011, 10:45 PM
First Name: art
I just got a Porter Cable 892, 2 1/4 HP fixed base. It appears that it is adjustable from above the table, requiring a 3/16" hex socket tool ($6.00 or so at Sears) or the specific PC tool carried by Amazon and other retailers, about $28-30.00.
I assume your 890 is the same. The info is contained in the manual, downloadable from Porter Cable.
HTH.
sanart is offline
post #7 of 8 (permalink) Old 01-17-2011, 02:16 PM
First Name: mark
Brother has the 892, his adjusts from the top with the tool. He loves it. I have the bosch, but I bought the rockler lift / plate. very happy with that set up.
mlstclair is offline
post #8 of 8 (permalink) Old 01-18-2011, 11:07 AM Thread Starter
I just bought the PC tool for $29. Thank your everyone
PRL-V2 Router Lift DarkFlame Starting Off 8 03-20-2011 08:01 PM
Router lift DougO General Routing 8 08-18-2010 10:53 PM
Rousseau 3002 Router Lift LS 46_trap Table-mounted Routing 2 02-18-2008 07:59 PM
anyone pull the springs out of a Porter Cable 890 plunge base? paulcomi Tools and Woodworking 8 04-23-2006 05:26 PM
