Pivot Fence - Router Forums
post #1 of 12 (permalink) Old 01-15-2011, 01:05 PM Thread Starter
Default Pivot Fence
I'm thinking about how to accommodate pivot fence motion when using t-tracks for both ends of the fence. Assuming that one end of the fence, say the left end when facing the table, is the pivot point, wouldn't the right end of the fence need to have a slot cut perpendicular to the t-track to allow for movement of the t-bolt?
A different situation would be if only one t-track was used and the other end was a fixed pivot point, in that situation the moving fence end would need an arced slot.
Is this correct?
Wobbly is offline
post #2 of 12 (permalink) Old 01-15-2011, 01:21 PM
Hi
Yes and no
If you use the left side for the pivot point than all you need to do free up the right side by removing the knob, the one I use is spring loaded on the right side..it just snaps into a 3/8" hole..quick and easy, no spring type just pull the knob and stud..but I will say if you use the tee track on the left side the hole will need to be bigger than the norm...( 5/8" works well ) for the fine adjustment..
Is this correct?
post #3 of 12 (permalink) Old 01-15-2011, 01:29 PM
Santé's Avatar
Country: Belgium
First Name: Daniel
Hi all
I did something like that. The entire guide can move forward or backward for quick adjustment, and then fine tuning is done with a pivot to the left and right thumb screw.
This guide can be seen on the website below
Name:	DSC01625 [640x480].JPG
Name:	DSC01627 [640x480].JPG
Member of the french site for woodworkers
www.lescopeaux.asso.fr
Santé is offline
post #4 of 12 (permalink) Old 01-15-2011, 05:41 PM
Hi
Here's my fine adjustment device, I got the tip from the router table pro's. Bob R. and Rick R. of the RWS, it's not high tech but it sure works in the KISS way.
Router Fence Micro Adjuster
Router Table Fence
" This router table fence Micro-Adjuster gives you great accuracy when using it in conjuction with your router table fence.
The clamp conveniently attaches to any standard router table and has a fine threaded micro adjuster mechanism built right in.
Also included in this set is a rare earth magnet that when engaged with the metal router fence tab and the micro adjuster it allows for easy push and pull adjustments to your router table fence.
* Provides superior routing accuracy
* Finely threaded screw micro adjusts
* Magnet attracts metal fence tab
* Push-pull adjustment from either side
* Onboard clamp attaches to router table"
post #5 of 12 (permalink) Old 01-15-2011, 06:08 PM Thread Starter
Is that metric or SAE?
Wobbly is offline
post #6 of 12 (permalink) Old 01-15-2011, 06:15 PM
Hi
hahahahahahahaha both ,well left hand or right hand device also
post #7 of 12 (permalink) Old 01-15-2011, 09:43 PM
collinstuart's Avatar
First Name: Collin
Default re:fine adjust
A simple home made fine adjuster
collinstuart is offline
post #8 of 12 (permalink) Old 01-15-2011, 10:29 PM
jeeper's Avatar
First Name: Larry
Love all the ideas from you guys!! Thanks for letting others know..
You know your gettin old when you sink your teeth into a nice big steak and they stay there.
jeeper is offline
post #9 of 12 (permalink) Old 01-16-2011, 04:00 AM
Mike Wingate's Avatar
First Name: mike
No one showing their digital readout, motor driven adjuster....?
Mike Wingate is offline
post #10 of 12 (permalink) Old 01-16-2011, 07:26 AM Thread Starter
This might serve the purpose with suitable modification: http://www.freeadsindiabiz.com/_mm/_...Goldberg01.gif
Wobbly is offline
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
Pivoting fence arc vs distance? Bogydave Table-mounted Routing 16 01-14-2009 08:49 PM
Very Long Pivot Fence mcelduff Table-mounted Routing 2 01-12-2009 07:41 AM
Pivot Fence Programme on Internet mcelduff Table-mounted Routing 0 01-12-2009 06:07 AM
