routering dovetails in plywood ? - Router Forums
post #1 of 7 (permalink) Old 01-16-2011, 09:12 AM Thread Starter
Default routering dovetails in plywood ?
can anyone tell me a story of how to router dovetails in plywood with min tear out
thanks.. peacefulwarrior
peacefulwarrior is offline
post #2 of 7 (permalink) Old 01-16-2011, 09:21 AM
Mike Wingate's Avatar
First Name: mike
This is not going to be good.
Mike Wingate is offline
post #3 of 7 (permalink) Old 01-16-2011, 09:32 AM
Hi
It can be done with good plywood (more than 4 layers without any voids in the plywood) and using a sharp (new) router bit. a good way to test the router bit,put some paper on a wood block and cut the paper with the router bit with one pull of the router bit,if it cuts the paper you are good to use it, if not it will rip the plywood.. but it will be dull real quick cutting the plywood...so get more than one, and use router bit lube.. if it's worth doing it's worth doing it right they say..
post #4 of 7 (permalink) Old 01-16-2011, 10:09 AM
amaonline's Avatar
First Name: Howard
You can, If I have done it you can too. Pay attention to Bob's post above, although I did not use the paper test. I recommend at least 7 ply and take your time setting your jig and bit depth, if the joint is the least bit too tight...Let's just say there is not alot of room for error!
Good Luck
amaonline is offline
post #5 of 7 (permalink) Old 01-16-2011, 10:39 AM
Ralph Barker's Avatar
First Name: Ralph
As Bob and Howard said, it can be done - with good plywood and sharp bits. That usually means Baltic Birch ply, or cabinet-grade ply, not the stuff from your local home-improvement store.
- Ralph
Ralph Barker is offline
post #6 of 7 (permalink) Old 01-17-2011, 06:26 PM
RJM60's Avatar
First Name: Robert
Don't forget using (sacraficial) backer boards
The single biggest problem in communication is the illusion that it has taken place.
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #7 of 7 (permalink) Old 01-17-2011, 07:36 PM
Gday
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
Dovetails In Plywood rmaxa Router Bits - Types and Usage 8 11-30-2010 05:42 PM
Dovetails in plywood jadrats New Member Introductions 7 06-12-2010 08:03 AM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
Finishing exposed plywood edges wthomaz General Routing 9 11-11-2009 01:43 AM
Plywood dovetails blarsen General Routing 10 09-28-2009 11:35 AM
