Cutting 45 degree with chamfering bit? - Router Forums
post #1 of 23 (permalink) Old 01-17-2011, 09:37 AM Thread Starter
First Name: curt
Default Cutting 45 degree with chamfering bit?
is it proper procedure to use a 45 degree chamfering bit to miter the corners for a small decorative box? better on a miter saw, or table saw rather than a router table? thanks
bakerscookin is offline
post #2 of 23 (permalink) Old 01-17-2011, 10:23 AM
First Name: Frank
Wood Magazine had an article on this technique awhile back. Google "Wood Magazine router techniques chamfering bits" It should take you to the article. Hope this helps.
Note: I am not allowed to post the URL because I do not have 10 posts.
Speyerer is offline
post #3 of 23 (permalink) Old 01-17-2011, 10:40 AM
HI Frank
Here's your link
Chamfer Bits
Just a note if you drop the URL call than you can post your URL links.
see below
(http://???) just use the address ▼
woodmagazine.com/woodworking-tips/techniques/routing/chamfer-bits/
Your browser will do it for you (auto) ,when you paste and copy the address to the line..
Just a note, the Chamfer Bits have a down fall, they are made for 3/4" thick stock the norm and as you know when you cut stock on a angle it gets longer so to speak..the thicker the stock the longer they are..that's why the MLCS bits work so well on any stock
post #4 of 23 (permalink) Old 01-17-2011, 12:28 PM
Gene Howe's Avatar
First Name: Gene
HI Frank
Bob, I'm geometrically challenged! I don't understand why a 3/4" cutting length couldn't be used on 1/2 material.
What am I missing?
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #5 of 23 (permalink) Old 01-17-2011, 01:01 PM
Hi Gene
It can be but most use 3/4" thick stock the norm, most don't have 1/2" thick stock around the shop, a easy way to get the job done without buying any bits is with the joinery, most of them can do any angle (up to a 45*) and the cutting blades are 6" long the norm many forget the it can do many jobs..
What am I missing?
post #6 of 23 (permalink) Old 01-17-2011, 04:50 PM
Ralph Barker's Avatar
First Name: Ralph
Hi Gene
Sorry, Bob, you've lost me on this one, too. You started talking about an MLCS bit, but in this post, it sounds like you're talking about doing the 45° chamfer on a jointer. Could you clarify, please?
- Ralph
Ralph Barker is offline
post #7 of 23 (permalink) Old 01-17-2011, 05:04 PM
Hi Ralph
Sorry ,that's true I guess and than Frank posted the Chamfer Bits to do other angles on the router table and I than said the jointer can do all the angles you need...not just the 45 deg.cut.
Ralph,,,Do you have a jointer ?
post #8 of 23 (permalink) Old 01-17-2011, 05:12 PM
First Name: Ralph
What am I missing?
It could, barely. The 45° chamfer cuts away what would be a right triangle, so you need to be sure that the "cutting length" listed for the bit is equal to or greater than the length of the hypotenuse of that triangle. For 1/2" stock, that's 0.70711, so a .75" cutting length would be OK. For 3/4" stock, the hypotenuse would be 1.0607", so a 1" cutting length would fall a touch short.
RIGHT TRIANGLE CALCULATOR
- Ralph
post #9 of 23 (permalink) Old 01-17-2011, 05:12 PM
RJM60's Avatar
First Name: Robert
My jointer does 45° cuts. The fence has a stop at 90° and 45°.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #10 of 23 (permalink) Old 01-17-2011, 05:31 PM
Hi Ralph
Say what ?
The fence on a jointer can be set both ways.. pos. and neg cut..
Name:	J fence.jpg
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
45 Degree lock-mire router bit rain Router Bits - Types and Usage 3 12-29-2009 12:14 AM
Fastest Bit for cutting 1/2 Plywood??? nicksorenson Router Bits - Types and Usage 2 06-02-2008 05:19 PM
What bit do I use for cutting tenons Johnny Dee Tools and Woodworking 4 02-07-2005 01:32 PM
cutting archs/circles (what bit to use?) mcbradford Router Bits - Types and Usage 2 01-06-2005 10:21 PM
