bit travel - Router Forums
post #1 of 7 (permalink) Old 01-17-2011, 03:48 PM Thread Starter
First Name: doug
Default bit travel
Why does my router bit rise up on its own when its in my router table
dgchstr is offline
post #2 of 7 (permalink) Old 01-17-2011, 04:13 PM
Ralph Barker's Avatar
First Name: Ralph
Most likely a sirty shaft and/or collet. Also, if you "bottom-out" the bit and don't retract is some, the collet often isn't able to grip the shaft properly.
- Ralph
Ralph Barker is offline
post #3 of 7 (permalink) Old 01-17-2011, 07:28 PM
G’day Doug
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #4 of 7 (permalink) Old 01-19-2011, 08:12 AM
First Name: Matt
Welcome Doug. If cleaning the collet and shaft doesn't work you could rough up the shaft just a little with some sandpaper.
mattgdraw is offline
post #5 of 7 (permalink) Old 01-19-2011, 09:11 AM
Hi Doug
This is the norm if the bit is not tight in the router, but I will say check the bit diam. to make sure it's dead on..all router bits are not made the same,but put the sand paper back on the work bench you don't want to remove stock you want one that's right on the button..
post #6 of 7 (permalink) Old 01-19-2011, 09:37 AM
Gene Howe's Avatar
First Name: Gene
Have the same problem with just one 1/4 bit with a 1/2 shank. It's a Katana bit and every other Katana I have has no problems. Nor does any other bit.
I mic'ed it at exactly 1/2". Collet was cleaned and bit was not bottomed out.
I'm thinking that maybe it has something to do with heat, as I was routing some longish 1/4" deep dadoes.
It's infuriating, isn't it?
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #7 of 7 (permalink) Old 01-19-2011, 08:21 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Doug.
Dave
the "Doctor"
Dr.Zook is offline
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
Dull router bit RonH Router Bits - Types and Usage 4 03-07-2009 06:59 PM
Broken bit Mortice Router Bits - Types and Usage 3 02-20-2009 11:51 AM
