Insert hole sizes. - Router Forums
post #1 of 15 (permalink) Old 01-19-2011, 08:00 AM Thread Starter
Country: South Africa
Default Insert hole sizes.
I have made a mounting plate for my "table to be" and am not sure as to what size holes to put into the insert plates.
I started with the plate which i felt was the most important part, (apart from the fence) and possibly the hardest to get right.
I found some fantastic material in my scrap pile. Rigid. Dark reddish brown in colour. 8mm (3/8) thick. Machines well with the shavings being light brown but emitting a rather unpleasant odor. It is similar to a "non-conduction" material I have seen in electrical equipment. Anyway.
I made the insert hole diameter 90mm (about 3 1/2 inches) which is the max my Hitachi M12V can offer. And I machined 2 inserts for different bit sizes holes. Now I need to cut the hole for the bits to come thru.
What are the recommended hole sizes I should make? Are there standards?
I want as much flexibility as possible as I am not sure what the future holds.
vaneric is offline
post #2 of 15 (permalink) Old 01-19-2011, 11:16 PM
MuzzleMike's Avatar
My table has a whole that is 3 inches across . I made it that way do to my biggest bit is 2 1/2 inches . People might not like this but it works for me I do not use any bushings with my router unless I am using by hand with my dove tail jig . I hope this helps but I would give your largest bit some room and go with that . If you need more in the futcher you always can make it bigger .
Have fun working with wood and be safe . .
MuzzleMike is offline
post #3 of 15 (permalink) Old 01-28-2011, 06:40 AM Thread Starter
Thanks Mike
I also made my hole size big. About 3.5 inches.
I have then made 2 3.5 inch inserts which i can make smaller holes in. A little concerned about safety so I though of different sized holes to match the cutters. With a 1/2 inch bit i could use the insert with a 1 inch hole. And a 1 inch bit with the 2 inch hole.
I was just carelessly asking if there were optimum sized holes. I do not have too many bits yet and do not know the "usually" used sizes.
Thanks for your reply.
vaneric is offline
post #4 of 15 (permalink) Old 01-28-2011, 07:36 AM
First Name: Dai
Hi
This is the set of eight moulded plastic insert rings that i bought for my Insert Plate - 54mm, 51mm, 47mm, 41mm, 34mm, 22mm, 16mm.
HTML Code:
http://www.rutlands.co.uk/workshop-&-power-tool-accessories/routers,-tables-&-lifts/router-table-inserts/TLRSETML/set-of-8-twist-lock-rings---moulded-plastic
Dai
Itbeme is offline
post #5 of 15 (permalink) Old 01-31-2011, 01:00 AM Thread Starter
Perfect Dai. Thanks.
A full range would be the safest. I can work it from here.
vaneric is offline
post #6 of 15 (permalink) Old 01-31-2011, 01:37 AM
Country: Germany
First Name: Titus
Vaneric, for information - your plate material is Phenolic sheet. I use the same for my plates.
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt
Titus A Duxass is offline
post #7 of 15 (permalink) Old 02-07-2011, 12:41 AM Thread Starter
Ok. Tightasa
Have seen this word frequently but not sure what everyone is refering to.
Fantastic material for the job.
I really enjoyed machining it.
Although does not machine as well with a 1/4 inch shank cutter. Vibrates a little.
vaneric is offline
post #8 of 15 (permalink) Old 02-07-2011, 11:04 AM
BigJimAK's Avatar
Mike,
Rather than try to tell you how many inserts to make/use and what sizes to use, I'll focus on the question of "why have multiple sizes".
Many decide based on the obvious: keeping the wood from dipping down into the hole or catching on the far edge but there's another consideration.
We install zero-clearance throat plates on our table saws to resist tearout. The same is true with routers. How much do you care and how far do you go making/buying inserts? That is matter of personal preference.
BigJimAK is offline
post #9 of 15 (permalink) Old 02-08-2011, 07:39 AM Thread Starter
Great point.
It never crossed my mind to consider this.
Tks.
vaneric is offline
post #10 of 15 (permalink) Old 02-08-2011, 09:02 AM
First Name: Steve
I too am new at this but my router table hole will not allow larger router bits to retract below the surface "I have a tablesaw and router combo" and I have to remove them when cutting on the table saw. Anyhow I use the insert as close to the shank of the bit
1/2 or 1/4 inch size hole. Am I wrong or what??
Also it sounds like the redish brown material could be bakerlite which is an insulator.
Bar clamp is offline
Samona Insert Plate bill0199 Table-mounted Routing 9 01-06-2012 02:30 PM
getting right benchdog insert for bushings spoonjig New Member Introductions 2 03-05-2010 02:13 AM
table insert plate size? awoodnut Table-mounted Routing 17 08-09-2009 09:10 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 04:29 PM
