To Lock or Not to Lock - that is the question - Router Forums
post #1 of 9 (permalink) Old 01-20-2011, 06:19 PM Thread Starter
Default To Lock or Not to Lock - that is the question
Hi, I just got my Freud 3000 mounted in a table and up an running. I left the springs in and use the above table gizmos for raising, lowering, etc. Got me to wondering if I still need to go under the table to flip the plunge lock or not. Seems like between the weight, 13+ lbs, and the spring tension, it would be held pretty firmly.
Just wondering what the thinking is on it.
John Schaben
jschaben is offline
post #2 of 9 (permalink) Old 01-20-2011, 07:08 PM
RJM60's Avatar
First Name: Robert
I lock mine.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #3 of 9 (permalink) Old 01-21-2011, 10:40 AM
I always want 25K RPM spinning blades under full control. Lock it.
Tempest is offline
post #4 of 9 (permalink) Old 01-21-2011, 12:19 PM
dovetail_65's Avatar
First Name: Dovetail
I would lock it. You will get slight vibration if you don't and whether you feel it or not it can and will effect the quality of cut. The lock helps tighten up the machine as a whole, play with it put pressure on it with the lock off and on and I think you will see what I mean.
dovetail_65 is offline
post #5 of 9 (permalink) Old 01-21-2011, 01:10 PM
First Name: Simon
Well you learn all the time. I hadn't even given this a thought. I just assumed as the router is held in the table it would be ok without locking.
I will lock in future , thanks.
Cheers Si
chickenslippers is offline
post #6 of 9 (permalink) Old 01-21-2011, 01:26 PM
Hi John
The 3000 is so well made you will not need to lock it, the lift will hold it in place just fine.
But that's just my 2 cents,I have not put my 3000 in the table..but the weight of the router will load the lift system just fine..
post #7 of 9 (permalink) Old 01-21-2011, 02:37 PM
Yes, but there is lateral play in that 3000. Very slight, but its there.
I would think if you bump the table or have a dull bit and are really pushing that it will give and spring back ever so little, but enough to give you ripple in say a cove bit profile that is a pain to sand out.
I think the real question here is; "Is there any reason not to lock it". No there is not. It can only help and not hurt.
I always pull the springs when I put a router under a table, but that's me.
I guess I gave 4 cents on that one.
post #8 of 9 (permalink) Old 01-21-2011, 05:08 PM
OPG3's Avatar
First Name: Otis
Think about it like this: One horsepower can move 550 lbs, 1 foot in 1 second. Now, determine how much a bit spinning 20K+ RPM with whatever your HP actually is at the RPM you're spinning. The 13+ pound router will seem like a fly on a horse's fanny. If you don't lock-down that router, you'll create some very ugly parts. Be safe! OPG3
OPG3 is offline
post #9 of 9 (permalink) Old 01-21-2011, 06:02 PM Thread Starter
Thanks for the input guys. Not to difficult for me to lock, would be a different story if I had large hands, lock kinda buried. Gotta go down there to adjust the speed anyway. I left the springs in to help keep the system biased (take up the slop). Did need to employ something of a power lift (internal hex socket with deWalt drill) to wind the thing up against the springs.
I ended up buying a table for it because I'm already so far behind on projects I didn't want another major one. Should have made my own top though. At least I can do the mods I have in mind between jobs rather than instead of.
John Schaben
jschaben is offline
Question about lock mitre set up distrbd Table-mounted Routing 4 05-09-2010 04:28 PM
22.5° Lock mitre bit question Mt-Pockets Router Bits - Types and Usage 6 12-10-2009 11:09 PM
