Box Joints: bit size vs wood size - Router Forums
post #1 of 1 (permalink) Old 01-24-2011, 10:13 AM Thread Starter
Zurt's Avatar
First Name: Burt
Default Box Joints: bit size vs wood size
I've been making box joints with 3/8" wood. When I use 3/8" Whiteside bits the boxes assemble easily and snuggly. When I use a 1/4" bit, the assembly needs a little kung fu. I'd like to try a 1/8" bit but I'm thinking I'll need a pile driver to assemble it.
Why so tight? I'm aware of the "rule" but I still don't understand the mechanics of this "rule." Shouldn't I be able to assemble a box joint of any size with any wood?
BTW, I'm using the Incra Ultra and it works like a dream.
Zurt is offline
how do i determine round over bit size? danielle Router Bits - Types and Usage 8 10-25-2017 01:37 AM
Best bit for tight fitting box joints? Nickbee Router Bits - Types and Usage 9 12-31-2007 12:13 AM
Best bit for box joints on the Oak Park Spacer S Bolton Router Bits - Types and Usage 7 09-05-2007 05:06 PM
Router bit burning the wood!!! rovailla Router Bits - Types and Usage 7 07-18-2007 02:15 AM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
