N00b with a plan. - Router Forums
post #1 of 2 (permalink) Old 01-26-2011, 09:57 AM Thread Starter
Default N00b with a plan.
Hey all-
Working on making my first router table. I took an old drafting table that I had, and kiped the top from it. It's 1/2" thick, and covered in melamine.
Mounted that to a 3/4" slab of plywood, with enough clearance around the edges to mount a lower fence of 4"x1" poplar. 2x4's make up the legs and braces, and the poplar fence extends out on one side about 6" so that I can fasten it to my table saw (Entry level Skil from Lowes), and also use it as an extension table.
I have the Jess-em basic plate that I will mount a Hitachi M12VC to, and I got a miter track and T-track for the table to mount the fence to, and I will be finishing the table this weekend.
What I'm planning is a fence with a T channel across the backs of the faces, mounted to a vertical piece on a sled so that I can slide the faces out to accommodate larger bits. Been looking at a lot of plans over the last couple weeks.
Anyway, that's about it, if you have any suggestions, tips, references, love to have them!
John
P.S. Yes, I will post pics when I finish the table.
JohnWP is offline
post #2 of 2 (permalink) Old 01-26-2011, 04:17 PM
First Name: Simon
Sounds good to me.
I think you should post pics as your going along,IMO, it may help you out in the long run. Bob noticed something I had done wrong from looking at one of my photo's and suggested how I fix the prob.
As for suggestions, I just looked at as many router table build threads as I could. Russ has a really great thread going with great pics each step of the way.
http://www.routerforums.com/table-mo...ay-w-pics.html
Cheers, Si
chickenslippers is offline
Looking for bathroom vanity plan fire angel Project Plans and How To 29 06-01-2013 11:07 PM
Plan: adj. router mount Johnmolding General Routing 4 10-04-2010 05:54 PM
Router top plan in mind mntbighker Table-mounted Routing 1 01-01-2008 06:25 AM
