Lift for a Freud FT 3000 - Router Forums
post #1 of 5 (permalink) Old 01-27-2011, 04:23 PM Thread Starter
First Name: Joe
Default Lift for a Freud FT 3000
or maybe it's the 2000. It is the monster sized plunge router.
I have a Raizer that is all messed up and so is the plate - a hand me down that was abused so what I'd like to do is start fresh.
Anyone have any opinions of what is out there that doesn't require a second mortgage to buy.
Rooky is offline
post #2 of 5 (permalink) Old 01-27-2011, 04:35 PM
No need for a lift for the FT3000. It raises and lowers with a hex wrench through the table top. Might want to speed up the process with a hex bit mounted in a cordless drill, though. Incra makes a plate for the FT3000 and Woodcraft sells it.
Wobbly is offline
post #3 of 5 (permalink) Old 01-27-2011, 04:52 PM Thread Starter
First Name: Joe
me bad - it's not the 300 but the 2200. That's why I hesitated...in sentence. Sorry
Rooky is offline
post #4 of 5 (permalink) Old 12-09-2013, 08:43 AM
First Name: Todd
Default Do NOT use a drill driver to raise/lower this router!
I tried using a drill driver to raise and lower this router. The internal gearing and mechanism is made of plastic. All it took was one incident with driver turning in the wrong direction while the mechanism was already at the end of range. Stripped.
tbeaulieu is offline
post #5 of 5 (permalink) Old 12-09-2013, 07:43 PM
I used a drill driver to raise and lower mine for awhile. Luckily I never messed mine up but it made me sufficiently nervous to switch over to one of these:
3/8" Drive Speeder Handle
John Schaben
jschaben is offline
Router lift for Freud FT3000vce? Tuthmose Table-mounted Routing 12 12-10-2010 10:35 PM
Table Mounting Freud 3000 woodman59 Table-mounted Routing 6 08-31-2009 01:05 AM
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
Rousseau 3002 Router Lift LS 46_trap Table-mounted Routing 2 02-18-2008 07:59 PM
