Tips for Creating a Zero Clearance Plate - Router Forums
post #1 of 13 (permalink) Old 01-28-2011, 05:32 PM Thread Starter
Zurt's Avatar
First Name: Burt
Default Tips for Creating a Zero Clearance Plate
My table saw is in need of a new ZCP. My bandsaw could use one as well. This is a good router project. I've got all kinds of wood. Are there any special tips or do I just cut a plate out and use a trim bit?
Thanks,
Burt
Zurt is offline
post #2 of 13 (permalink) Old 01-28-2011, 05:37 PM
First Name: Simon
I have only made one for my table saw and I used plywood. The ply was thicker than the original plate so I had to rout a rebate around the edges to get the same thickness. Once I had a perfect fit I started the table saw and raised the height of the blade.
This has worked perfect for me ever since.
Cheers ,Si
chickenslippers is offline
post #3 of 13 (permalink) Old 01-28-2011, 08:23 PM
Hi Burt.
You can use 1/2" MDF to make a zero clearance plate for you table saw. I have made many for my Delta saw. I use screws underneath where the tabs are it sits on for height adjustment. I also insert a cutoff finish nail in the end of the plate on the far side so the plate is not lifted by the blade in use.
I clamp a board over the plate to hold it down & raise the blade to make the zero clearance. Make sure your blade is not hitting the bottom side of the plate before you turn on the saw.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 13 (permalink) Old 01-28-2011, 11:39 PM
I use HDPE scrap that I get for cheap at a plastic supply house. It's tough, easy to route, and will accept threads for leveling screws. You can also use cheap plastic cutting boards for the same thing.
Just cut it to rough size, double stick tape it to your original metal plate, and then flush trim on the table.
Tempest is offline
post #5 of 13 (permalink) Old 01-29-2011, 07:42 AM Thread Starter
Zurt's Avatar
First Name: Burt
My current plate was made from cheap scrap plywood that I cut on the bandsaw. At that time, I didn't have a router so I sanded it to get it to shape. It's fugly and funky but it works. Kinda.
Now that I'm set up with a table and 3 routers I think it's time for a new plate. Just wasn't sure if there were some neat tricks. Guess it's all the obvious stuff.
Thanks for the advice,
Burt
Zurt is offline
post #6 of 13 (permalink) Old 01-29-2011, 07:46 AM
TwoSkies57's Avatar
Burt...
Make up a several blanks while your at it...throw em on a shelf for later on.
Skipper the Penguin
TwoSkies57 is offline
post #7 of 13 (permalink) Old 01-29-2011, 07:54 AM
Originally Posted by TwoSkies57 View Post
Burt...
Good idea Bill. I made a template out of 1/4" MDF and saved that so I can whip them up pretty quick. Made me nervous running that close to the steel insert.
John Schaben
jschaben is offline
post #8 of 13 (permalink) Old 01-29-2011, 04:04 PM
BigJimAK's Avatar
John,
Didja use the steel insert to make the template?
Jim
BigJimAK is offline
post #9 of 13 (permalink) Old 01-29-2011, 04:08 PM
Originally Posted by BigJimAK View Post
John,
Jim
yep, spaced it up with a couple of scraps of 1/4" MDF and carpet tape though. Still made me nervous
John Schaben
jschaben is offline
post #10 of 13 (permalink) Old 02-01-2011, 03:14 PM
First Name: Jay
A few folks on another forum have reported that HDPE and UHMW tend to sag after a while.
I'm probably going to order some phenolic from McMaster when I get ready for some new inserts. $35ish buys a sheet of the plain brown paper phenolic that's 12x24; enough for six inserts for my saw. Or three inserts and a new router plate. Or two plates and no inserts. Or...
At any rate, it averages out to a pretty reasonable price for nice plates that won't sag. If I need to chop one up during use (angle cuts, dado steck, etc.), I have a couple of 1/2 MDF plates.
Cavediver is offline
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
Old Rockler aluminum mounting plate inserts Mike Table-mounted Routing 0 07-07-2009 09:57 PM
Mounting a router plate questions / tips? Nickbee Table-mounted Routing 3 11-29-2007 10:26 AM
router table top delroy33 General Routing 18 07-30-2006 04:53 AM
