Glue in End Grain Box Joints - Router Forums
post #1 of 5 (permalink) Old 01-29-2011, 10:27 AM Thread Starter
Zurt's Avatar
First Name: Burt
Default Glue in End Grain Box Joints
I'm making a lot of tissue boxes for the wife. I'm using my Ultra to speed things along. My big problem now is the glue ups. I get a bit of glue (titebond/titebond extenze ) here and there. On the side grain I wipe it off with a damp rag. No problem. Gone. However, on the end grain. no amount of wiping gets it off. I scrape and sand but it still blocks the finish (Antique Oil).
Any tricks you'd care to share?
Thanks,
Burt
Zurt is offline
post #2 of 5 (permalink) Old 01-29-2011, 10:34 AM
Hi Burt
Mix up some White Vinegar and some bottle water in a spray bottle, spray the 50/50 mix on the over flow and wipe it off with a clean rag.. don't use the rag over and over use a clean one..
Thanks,
Burt
post #3 of 5 (permalink) Old 01-29-2011, 12:07 PM
Capecarver's Avatar
First Name: Steve
Perhaps if you cut the pins a little long and then trim/sand them flush?
Capecarver is offline
post #4 of 5 (permalink) Old 01-29-2011, 01:08 PM
Hi
The end grain is like little straws and will soaked the glue up, it must be removed b/4 it can seal the wood..once dry that's it.. it will not take on any finish..
post #5 of 5 (permalink) Old 01-29-2011, 09:41 PM
Prefinish the end grain before you glue up. That will create a seal to help prevent the glue from soaking in.
Tempest is offline
new amature wants to make box end joints meyerse New Member Introductions 2 06-02-2010 12:17 AM
Need help setting up for 1/4" box end joints economically(guitar amps/speaker cabs) Zappacat Table-mounted Routing 1 07-18-2009 10:36 AM
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 17 06-22-2009 12:42 PM
OP Box Joints and Wood Grain CanuckGal Starting Off 5 01-27-2009 10:33 PM
