table saw router? - Router Forums
post #1 of 17 (permalink) Old 02-01-2011, 05:13 PM Thread Starter
First Name: Kevin
Default table saw router?
Has anybody used an old table saw table and made into a router table? I have a table saw that the motor burned up and was going to use it. Any pictures or tips of what to and not to do would be good.
mac_y44 is offline
post #2 of 17 (permalink) Old 02-02-2011, 09:05 AM Thread Starter
First Name: Kevin
Nothing?? Maybe I will be the first.
mac_y44 is offline
post #3 of 17 (permalink) Old 02-02-2011, 09:10 AM
kp91's Avatar
First Name: Doug
Mac,
I've heard of people thinking about doing it, but I can't recall any completed ones. I personally think it might be more trouble than it's worth. I prefer to mount my router to an insert plate, and modifying a cast iron table saw top to accept a plate might be a challenge if you don't have access to a fair size milling machine.
I would be interested in seeing what you come up with!
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 17 (permalink) Old 02-02-2011, 09:17 AM
Hi Kevin - seems I remember someone doing it about a year ago. They posted some pics of it but I haven't been able to find the thread. Seems I remember they mounted the router underneath with a throat plate insert. I also seem to remember that they were only able to get two bolts afixed there for some reason.
Don't rely to much on my memory though, have trouble picking up milk with out a note pinned to my shirt
John Schaben
jschaben is offline
post #5 of 17 (permalink) Old 02-02-2011, 09:19 AM
HI Kevin
Nope , a new member posted some pictures about 30 days ago of doing just that.
I don't recall his name but he made a insert plate for the router bit to pop out of the table saw if I recall..maybe with some luck he will see your post and pop in..
post #6 of 17 (permalink) Old 02-02-2011, 09:23 AM Thread Starter
First Name: Kevin
Thanks Doug, I have a knee mill and just might give it a try. Also the cast iron table saw top you are talking about is what I was wanting to try. Do you have one like this? I don't have a router yet, still shopping around. What is the insert plate you are talking about?
Thanks Kevin
mac_y44 is offline
post #7 of 17 (permalink) Old 02-02-2011, 09:26 AM Thread Starter
First Name: Kevin
We must all been typing at the same time. I can do the metal fab thing, sometime it is just a good challenge to see if it can be done..
mac_y44 is offline
post #8 of 17 (permalink) Old 02-02-2011, 09:54 AM
Ralph Barker's Avatar
First Name: Ralph
If you can mill a new receiver hole that would fit one of the typical router insert plates, it might work nicely. Otherwise, the size of the usual TS insert plate would be a problem, I'd think - too narrow to allow convenient access to the router. The webbing on the underside of the cast table might also present a challenge.
- Ralph
Ralph Barker is offline
post #9 of 17 (permalink) Old 02-02-2011, 10:11 AM Thread Starter
First Name: Kevin
Thanks Ralph, do you think putting the router where the blade was or move it off to the side a bit?
mac_y44 is offline
post #10 of 17 (permalink) Old 02-02-2011, 02:14 PM
I'm with Ralph on this one. I would try to avoid cutting out ribs, even partially. The top is cast as a unit and it would be hard to predict what stresses that might cause. If there is enough space where the blade was to mount the router that's where I would try to put it.
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 15 01-26-2015 02:30 AM
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
Craftsman 2hp professional router table combo... Duane867 Table-mounted Routing 2 01-03-2010 11:12 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
