Triton 2.25 hp switch - Router Forums
post #1 of 4 (permalink) Old 02-10-2011, 01:14 PM Thread Starter
First Name: Kelly
Default Triton 2.25 hp switch
Can you tape the switch on the Triton 2.25 hp router so it is controlled by another switch. It would always be on, at the router, but you use a switch to turn it off and on.
KR
Kelly Rittgers is offline
post #2 of 4 (permalink) Old 02-10-2011, 01:52 PM
First Name: George
Hi Kelly,
There is a plastic guard over the switch that enables you to turn it on and it will stay in that position. I use it this way in my router table, with the router plugged into a switch box.
If you are using it in a router table, the only time you will have to reach under and turn it off, is when you want to extend the collet up thru the table to change bits. When the trigger is held in the on position, there is a safety device that will not let you extend the bit all the way to the "locked" position. This prevents you from accidentally turning the router on with the shaft locked.
I've had my Triton for about a year, and I love it.
-George
Capt Splinter is offline
post #3 of 4 (permalink) Old 02-10-2011, 02:57 PM Thread Starter
First Name: Kelly
Thanks. A lot of people like the Triton and some don't. Seem like a good buy.
KR
post #4 of 4 (permalink) Old 02-12-2011, 05:52 PM
First Name: downhill
If....you are handy, you can rewire that switch so it's always hot. If you do this..cut the end of the plug off and wire it directly to your new switch so you won't be tempted to use it out of the table.
This will allow you to keep the switch closed
downhill is offline
Triton Router switch problem Gleneil General Routing 21 07-23-2018 09:28 AM
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Important information regarding TRITON harrysin Lobby 1 01-05-2010 08:08 PM
Urgent Request For Triton Workstation Switch Al Robins Lobby 5 09-10-2009 04:43 PM
That Triton "safety" switch! crquack General Routing 23 05-21-2009 09:41 PM
