Sanding Drums - Router Forums
post #1 of 4 (permalink) Old 02-19-2011, 01:42 PM Thread Starter
Ken Bee's Avatar
First Name: Ken
Default Sanding Drums
This may be a bit over the top, but I am going to ask anyhow.
I was in one of our local hardware stores the other day and was looking at some drum sander arbors and disks in 1-3 inch diameters and the instructions stated they could be used from 10,000-35,000 RPM depending on size.
Now here is the question. why could they not be used in a router table if one doesn't another means of using them?
Ken Bee is offline
post #2 of 4 (permalink) Old 02-19-2011, 02:32 PM
dutchman 46's Avatar
First Name: Howard
One of the best reasons not to do that is the speed! If there is any thing that is out of round, and I will guess that it is, The table may be rattling around, and may come apart, or the router collet may not stay tight . I certainly would hate to get hit with the arbor, at that speed!
John 3:16
dutchman 46 is offline
post #3 of 4 (permalink) Old 02-19-2011, 02:37 PM
Phil P's Avatar
First Name: Phil
Are you sure they didn't have the decimal point in the wrong place? 10k to 35k RPM sounds a tad high - 1k to 3.5k doesn't
Phil P is offline
post #4 of 4 (permalink) Old 02-19-2011, 03:11 PM
Hi Ken - I'm kinda with Phil on this one. Sanding drum at 20k would likely start a fire faster than a boy scout on steroids.
John Schaben
jschaben is offline
How To Finish Sanding Moulding Of Door? Gaia The Finishing Touch 8 01-11-2011 02:32 PM
Sanding sealer ? dwayne423 Lobby 15 12-16-2009 03:33 AM
Sanding Tips pmspirito Tools and Woodworking 7 05-22-2009 08:49 AM
Sanding Sealer - What is it? Thrifty Tool Guy The Finishing Touch 11 02-21-2009 08:28 AM
Sleeveless sanding drums crquack Tools and Woodworking 13 02-15-2009 06:45 AM
