stupid question - Router Forums
post #1 of 6 (permalink) Old 02-20-2011, 08:48 AM Thread Starter
First Name: Eddie
Default stupid question
This is probably a stupid question...
Will any router table work with any router or do you have to buy the table made for that brand?
haglered is offline
post #2 of 6 (permalink) Old 02-20-2011, 09:19 AM
Hi Eddie
That's a Yes and No ..thing...some router tables can't take on any router..
post #3 of 6 (permalink) Old 02-20-2011, 09:30 AM
Ralph Barker's Avatar
First Name: Ralph
To expand on Bob's yes/no, I'll add an "it depends".
Although Brand X would like you to buy both a Brand X router and a Brand X table, that's not required. There are two issues to look at:
1. the convenience of pre-drilled holes that match, and
2. physical size/weight issues.
You can usually re-drill holes in the RT plate to match your router, using the router base as a template. Squeezing 15 inches of router into a 10 inch space, however, is another matter.
- Ralph
Ralph Barker is offline
post #4 of 6 (permalink) Old 02-20-2011, 09:31 AM
AxlMyk's Avatar
A GOOD table can be adapted to most routers by drilling the correct mounting holes in the insert plate.
I wouldn't put a large router in a table with less than a 1 1/2" thick top.
AxlMyk is offline
post #5 of 6 (permalink) Old 02-20-2011, 09:43 AM
Country: Germany
First Name: Titus
Whereas I am completely happy with just a 19mm (3/4" old money) Multiplex Ply top for my Trend T11.
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt
Titus A Duxass is offline
post #6 of 6 (permalink) Old 02-20-2011, 01:26 PM
TWheels's Avatar
It seems to me the real question is "will any router table work with any base plate?" Certainly the table top must be strong enough to support the router and remain absolutely flat. The O-P table top supports my Makita 3 1/2 hp router quite well. The O-P table top is 3/4 in (19 mm) thick. The square baseplates used in the O-P table top can accomodate or be drilled to accommodate any router I know of.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
Stupid is as stupid does TwoSkies57 Shop Safety 19 01-21-2011 06:43 PM
Rookie here, got a question wyatt earp New Member Introductions 6 07-18-2008 08:33 AM
Very Rookie Question Schu4598 General Routing 8 11-15-2005 08:42 AM
