Homemade insert - Router Forums
post #1 of 5 (permalink) Old 02-25-2011, 10:37 AM Thread Starter
Hudson River Rick's Avatar
First Name: N/aRick
Default Homemade insert
Good morning,
I asked a question the other day about inserts for router plates and the replys I received were very helpful, thanks. I thought the ones I located were a bit expensive for just a plastic ring, so I measured one and made my own using a circle cutting jig on my bandsaw. I used 1/8 inch acrylic that I purchased from a glass shop, it was very inexpensive, in fact if he had a piece in the scrap pile he would have given it to me, but he had to cut me a small piece.
It is sold as 1/8 inch, but it really is a bit smaller, perfect thickness. I cut a 4 inch circle then sanded it just a bit and used a hole saw to cut a 2 inch circle and I was in business. I was able to use my 1/2 inch round over bit and the dust collection seems to work better I think because the relief around the cutter is smaller.
Anyway, ir works great and I will be making more inserts as needed.
Hudson River Rick is offline
post #2 of 5 (permalink) Old 02-27-2011, 12:08 AM
First Name: Colin
Good for you ... no reason why someone with a bit of innovation and talent cannot make items like this. Well Done !!
Collett is offline
post #3 of 5 (permalink) Old 02-27-2011, 01:03 AM
First Name: Tim
Use Acrylic, it's hard and machines easy. Use your router with a circle jig to cut several 4"circles. Make them with a 1/4" hole in the center, then open them to fit what you need for a zero clearance bottom supporting insert. Finish the edges with a tool bit in your drill press then polish or sand fine with something like alum.polish. If you don't have a drill press then just use an arbor bolt thru the 1/4 hole and carefully spin them against some sand paper on a square block.
Slomoe is offline
post #4 of 5 (permalink) Old 02-27-2011, 01:16 AM
01stairguy's Avatar
First Name: Ron
awesome! how about some pics, thanks
01stairguy is offline
post #5 of 5 (permalink) Old 02-27-2011, 09:09 AM
Just another approach. On an old router/shaper I used to have I made a disc template out of 3/4" stock then for subsequent inserts all I had to do was cut the plastic into squares and double face tape the template to the plastic and use a flush cut bit on the table to make the insert.
John Schaben
jschaben is offline
Samona Insert Plate bill0199 Table-mounted Routing 9 01-06-2012 03:30 PM
getting right benchdog insert for bushings spoonjig New Member Introductions 2 03-05-2010 03:13 AM
Insert plates - again! crquack Table-mounted Routing 5 12-17-2009 04:19 PM
ZC Insert kolias Tools and Woodworking 7 01-01-2009 11:17 PM
Homemade Router Table Insert Question? deck99 Jigs and Fixtures 3 07-04-2006 12:56 AM
