Routing irregular shaped pieces - Router Forums
post #1 of 9 (permalink) Old 02-25-2011, 09:37 PM Thread Starter
Lakelad's Avatar
First Name: Gary
Default Routing irregular shaped pieces
I am new to routing and have a bench top router table and want to route an irregularly shaped piece using the table. I notice in videos online that most people doing this sort of thing have a pin which they can lean the work against while routing. My table does not have a pin, can the irregular shape still be accomplished. I am only going to do a round over on the piece.
Thanks, Gary
Lakelad is offline
post #2 of 9 (permalink) Old 02-25-2011, 09:55 PM
Hi Gary
You can add a starter/safety pin to your router table very easy, just drill a hole and tap it out to fit a brass bolt in ,without the head..it's best to have one on your table so it's worth the time to do it...
Thanks, Gary
post #3 of 9 (permalink) Old 02-25-2011, 10:00 PM Thread Starter
Lakelad's Avatar
First Name: Gary
Thanks, how about placement of the pin?
Gary
Lakelad is offline
post #4 of 9 (permalink) Old 02-25-2011, 10:12 PM Thread Starter
Lakelad's Avatar
First Name: Gary
Another question I have is where do you get the pins. Looks like a real easy solution, I appreciate the help.
Gary
Lakelad is offline
post #5 of 9 (permalink) Old 02-25-2011, 10:14 PM
Hi Gary
Can't say for sure without seeing a snapshot of your router plate, but the norm is to the right of the router bit about 2" to 2 1/2" from the bit.
Brass pin, stop by a ACE hardware store pickup a brass bolt, a long one with some clear shank on it (without threads)cut it off and put a slot in it .
You only need to end up with about 1/2" threads on one end and slot on the other end..so to say you need to cut off some threads and the other also...
You can also buy a lawn mower wheel bolt, that's a shoulder type at ACE and all you need to do is cut off the head..
Gary
post #6 of 9 (permalink) Old 02-28-2011, 02:01 PM Thread Starter
Lakelad's Avatar
First Name: Gary
Thanks for all of you help. I need to visit the hardware store.
Gary
Lakelad is offline
post #7 of 9 (permalink) Old 02-28-2011, 06:13 PM
Gary
Just another thought. A nylon spacer with a bolt makes a nice one also.
John Schaben
jschaben is offline
post #8 of 9 (permalink) Old 02-28-2011, 06:39 PM
Hi
Just one more way, pickup a Allen Cap screw, push on some hard plastic tubing over the cap screw..in that way you don't need to cut off the bolt or the head..
Both items from ACE hardware...
post #9 of 9 (permalink) Old 03-03-2011, 10:37 PM Thread Starter
Lakelad's Avatar
First Name: Gary
Thanks for the ideas. Need to get to ACE.
Gary
Lakelad is offline
Tearout routing small pieces of red oak the_nite_owl Table-mounted Routing 3 12-22-2009 08:40 AM
Routing small pieces using a handheld router geneengel General Routing 9 11-18-2009 02:50 AM
Routing small pieces Hamlin Jigs and Fixtures 11 10-25-2009 05:35 PM
Routing small pieces of timber colbra General Routing 11 07-01-2009 07:51 AM
routing small pieces zxxer12 General Routing 9 03-21-2005 04:40 PM
