Routing for a pinewood derby car - Router Forums
post #1 of 16 (permalink) Old 03-01-2011, 10:31 AM Thread Starter
First Name: Chris
Default Routing for a pinewood derby car
I currently am routing the underneath of derby cars with a small Proxxon router. My lines are not straight and would like them to be. I am getting into adult league racing and need to be able to make a consistent car. Since I'm a newbie, the site won't let me insert a weblink. If you go to youtube and search "Pinewood Derby weight pocket routing" there is a video showing a guy who has a jig set up for his router for pinewood derby. I'm uncertain if the Proxxon router is too small to set up this way (underneath). The 1/8" (3.2mm) router bit does not extend very high to make the cut through the underneath of the jig board. I typically route approximately 1/4" to 5/16" into the wood piece. One thought I had was to make an 'upside' down jig. Would place the Proxxon router on top. I've never made a jig, so layman terms would be nice. Thanks all - there is a wealth of knowledge here. Some posts have giving me ideas of other areas to try. Thank you.
Advance The Man is offline
post #2 of 16 (permalink) Old 03-01-2011, 11:05 AM
Hi Chris
The jig in the video looks Very unsafe, I would suggest you use a template and the bit below..any time you drop stock on the bit in a floating mode you are asking for it..
Amazon.com: Milescraft 2216 1/2-Inch Bearing Guided Straight Router Bit for Mortising: Home Improvement
you can make a quick template by gluing up some 1/2" thick MDF sticks to make the sq. pocket you need..and use some tape "DSCT" to hold the parts in place.
Note once you have the pocket in place than cut the stock down to size..
YouTube - Pinewood Derby weight pocket routing
Proxxon Micro Router MOF
post #3 of 16 (permalink) Old 03-01-2011, 11:33 AM
Ralph Barker's Avatar
First Name: Ralph
There are numerous ways to approach the objective. Like Bob, I don't think I'd suggest the method shown in the video, since it appears his jig is attached to the router, and the router is just sitting on the floor, wobbling back and forth. One slip, and his fingers will be in the bit, and the workpiece will be stained blood-red.
My preference would be a jig that holds the workpiece firmly in place, and then defines limits for the travel of the router, with the router being on top, so you can see what is being done. The task of defining the horizontal travel of the router could be done with either a template arrangement (with bearing-equipped bits or guide-bushing guides), or via stop blocks against which the router base would ride at the limits of travel. Either approach (template or stop blocks) would work.
The template approach would add a vertical depth-of-cut issue, particularly if limited to a bearing-equipped bit, since the template would need to be thick enough to provide a surface for the bearing to ride against for the entire depth-of-cut range.
The design of the jig, of course, depends on how you prefer to approach the cut, and how often you'll be using the jig.
- Ralph
Ralph Barker is offline
post #4 of 16 (permalink) Old 03-01-2011, 11:42 AM Thread Starter
First Name: Chris
Hi Chris
The Amazon link is for 1/2", which (I don't think) fits the Proxxon's max of 1/8". What are "thick MDF sticks" and "some tape "DSCT""?
Thank you both for the comment of the youtube video. I'll take that to heart and not go that direction. This is the only use I have right now for the router. With more experience, I'll venture out. But, I'm able to make a jig for this specific use and don't plan on moving it on and off very much or at all. Are there pictures of different jigs for similar purposes? I find a picture is a 1,000 words as they say.
Oh, and I need to hurry up and get to 10 posts so I can quote your links.
post #5 of 16 (permalink) Old 03-01-2011, 11:46 AM Thread Starter
First Name: Chris
I'm really a novice, but I promise I learn quick. So the bearing guided router bits will 'glide' along the outside boundaries? Are these made in hobby sized bits? i.e. 1/8" or 3.2 mm?
post #6 of 16 (permalink) Old 03-01-2011, 02:33 PM
Hi
You may want to use a mates router for this easy job..
DSCT= Double Sided Carpet Tape
MDF = Man made wood that is very flat and easy to use..
Here's some other templates that the bit is use for..
Amazon.com: Milescraft 1213 Complete Door Mortising Kit: Home Improvement
post #7 of 16 (permalink) Old 03-01-2011, 06:25 PM
First Name: Ralph
I've never seen bearings for 1/8"-shaft bits, but they might be out there.
For your "hobby" router, it looks like you'll be limited to using stop blocks or the edge guide to limit the travel of the router base, and thus the area being cut. As long as you have an even surface for the router's base to ride on, you'll be OK. In some instances, for example, you might need to put a thin sheet of MDF (medium-density fiberboard) or tempered hardboard (Masonite) over the work, with a cut-out for the bit to work within.
- Ralph
post #8 of 16 (permalink) Old 03-01-2011, 07:34 PM
First Name: Ralph
Here, as an example, is one approach to a jig for routing out your weight cavities with your Proxxon router.
The rabbets on the edges of the boards hold the workpiece down, and the blocks on top limit the travel of the router base, thus defining the dimensions of the cut-out. This approach assumes that the workpieces are going to be of consistent thickness - e.g. the same dimension as the rabbet.
- Ralph
post #9 of 16 (permalink) Old 03-01-2011, 07:54 PM
Hi
Yes you can get bearings for a 1/8" router bits from just about any bearing supply outlet..
Some router bits come with them on some round over bits and others they are in place a with Allen screw on the top of the bit...
Note ***if you have a inlay set it will do the job also with a 1/8" shank bit, it that way you don't need any bearings for the bit...but I'm not to sure if your router can take on the brass guides only you know that..
http://www.routerworkshop.com/inlays112.html
http://www.routerworkshop.com/inlay0802.html
http://www.harborfreight.com/solid-b...kit-99552.html
Making a template is easy, see below..
Bearings
MLCS Woodworking Adaptor Bushings and Ball Bearing Guides
Amazon.com: Dremel 692 6-Piece Router Bit Set: Home Improvement
Amazon.com: 10 pc. Mini Router Bits Set (For Dremel Tools): Home Improvement
1/8" lock collars from ACE Hardware.you will need two of them.
Name:	pocket template.jpg
post #10 of 16 (permalink) Old 03-01-2011, 08:00 PM Thread Starter
First Name: Chris
Thank you both for the picture. I'll draw up a plan and try it.
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
A routing tutorial for beginners Part Four harrysin Guide Bushings and Templates 23 04-21-2013 09:31 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
JIGS CAN MAKE ROUTING SAFER!! (lesson learned for a newbie) metzgeri Jigs and Fixtures 44 01-25-2011 11:00 AM
