EZ Pro Dovetail Jig from General Tools - Router Forums
post #1 of 19 (permalink) Old 03-04-2011, 11:18 AM Thread Starter
First Name: Kelly
Default EZ Pro Dovetail Jig from General Tools
I know there have been posts about this jig. Man the price seems right. What is the learning curve for 1/2 blinds in 1/2 inch stock?
KR
Kelly Rittgers is offline
post #2 of 19 (permalink) Old 03-04-2011, 11:22 AM
Hi KR
No big deal just use the gauge on the jig to set the bit at 3/8" deep the norm..
KR
post #3 of 19 (permalink) Old 03-04-2011, 11:24 AM Thread Starter
First Name: Kelly
$40.00. Can I go wrong? Off to the store soon.
KR
post #4 of 19 (permalink) Old 04-06-2011, 11:27 AM
First Name: will
I returned mine, very difficult to use.
volunteers is offline
post #5 of 19 (permalink) Old 04-06-2011, 01:45 PM
First Name: Roger
I, for one, thought it was very easy to use. Did I miss something??
It's possible I'm using it wrong, it has happened before.
Do as you always do,,, Get what you always get
rcp612 is offline
post #6 of 19 (permalink) Old 04-06-2011, 02:22 PM
HI Roger
Nope I don't think so, I have many of the dovetails jigs and the EZ dovetail jig is one of the simple ones to use and setup.
post #7 of 19 (permalink) Old 04-06-2011, 05:10 PM
First Name: will
so I must miss something. Did you use it on table router or regular router?
Maybe because the width of my work is too big? (about 20 inches)
post #8 of 19 (permalink) Old 04-06-2011, 07:38 PM
Hi Will
On the router table, 20" is not to bad, in the kit you will see a black plug for anything longer than 6", it's put in one of the pockets to setup for the next 5 pockets..and so on..
post #9 of 19 (permalink) Old 04-14-2011, 10:53 AM
First Name: Gary
Default General DoveTailer - Jury is still out
I picked up one of these at Home Depot recently. Finally got around to using it yesterday.
First of all, mine was warped! as in the jig is slightly twisted down the long axis and it won't sit flat on the table. But from the comments I've read here (thanks for SO MANY helpful comments in all areas) I have to assume (how I dislike that word) that warpage is not common.
I am trying to make simple through dovetails in 12mm (slightly less than 1/2 inch) stock. I set the bit 1/2" deep using the template, but apparently that was too long - I didn't get clean cuts along the "wide" end of pins. I set the bit about 3/32" shallower and got clean cuts. I haven't cut the po
Also I had problems with the bearing riding up on the shank. I had to stop a few times to set it back down. I'm not sure if another bearing (I used both) or a 1/4" stop collar is the best solution here.
FWIW my router is a Bosch 1617 with the RA1165 undertable base.
Oh, and I guess I should mention that this is the first time I've attempted dovetails
My 2 cents,
Gary
GEBrown is offline
post #10 of 19 (permalink) Old 04-14-2011, 10:55 AM
First Name: Gary
I am trying to make simple through dovetails in 12mm (slightly less than 1/2 inch) stock. I set the bit 1/2" deep using the template, but apparently that was too long - I didn't get clean cuts along the "wide" end of pins. I set the bit about 3/32" shallower and got clean cuts. I haven't cut the pockets yet.
My 2 cents,
Gary
Sorry, now it looks like a double post - I didn't finish "cut the pockets yet" the first time - duh!!
GEBrown is offline
Black & Decker Dovetail Jig Ross72 Jigs and Fixtures 15 04-18-2012 11:16 AM
Dovetail jig or Incra system for table use? AlanZ Jigs and Fixtures 16 02-09-2011 11:28 AM
Rockler Dovetail Jig jschaben Jigs and Fixtures 3 08-21-2009 09:31 AM
Dovetail Jig question RichLig Jigs and Fixtures 2 12-21-2008 12:10 PM
Sliding DoveTail Jig bobj3 Jigs and Fixtures 5 01-06-2007 08:31 PM
