loose levelling screws - Router Forums
post #1 of 20 (permalink) Old 03-07-2011, 06:02 AM Thread Starter
First Name: Gail
Default loose levelling screws
Newbie here. I'm happily using my PC router in my Jessem table top router table.
Only problem, the levelling screws are quick to loosen. Is there something I'm missing? I get the plate nicely levelled. Rout a bit and find the screws have backed out.
woodburl is offline
post #2 of 20 (permalink) Old 03-07-2011, 07:43 AM
kp91's Avatar
First Name: Doug
I'm not familar with the Jessem table, but if the screws go all the way through the supports, you could put a dab of nail polish on the threads after you have it all leveled. Once it dries, it should help keep your screws from vibrating down, but be easy enough to remove should you have to readjust.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 20 (permalink) Old 03-07-2011, 08:46 AM
N'awlins77's Avatar
First Name: Lee
Well I wasn't having that problem, that I noticed yet, but my Hart Design plate, because how I have my table hinged on my cabinet (lifts up like a car hood), I had to add a couple of hold-down screws to it. When I would have the table raised, and I was inserting or removing a bit, my router and plate would jump out of place. So I added two #8 flathead screws through the plate and table, and used wing nuts under the table. I don't pull down hard, just a tad. Maybe something like that would help you too. Although, the idea of the finger nail polish might work well for your problem.
N'awlins77 is offline
post #4 of 20 (permalink) Old 03-07-2011, 01:28 PM
Ralph Barker's Avatar
First Name: Ralph
I'm not sure of the setup on the Jessem, but my plate adjustment screws go through brass threaded inserts from the bottom of the table. To keep them in place, I simply added a washer and a lock nut, which is tightened after the adjustment is made. The lock nut creates tension between the threaded insert and the nut, so it stays in position.
- Ralph
Ralph Barker is offline
post #5 of 20 (permalink) Old 03-07-2011, 02:12 PM
Kinda interesting. I couldn't get two of the leveling screws started on my Incra plate. Anodizing got into them. Figured I could just chase the threads with a 1/4" tap but wasn't sure of the size, metric, whatever, so I e-mailed INCRA. Turns out they use 1/4-28 setscrews and 1/4-27 threaded holes.
Anyway, I would suggest the blue (medium strength) loctite thread locker. Don't use the red or green high strength if you ever want to adjust them again.
John Schaben
jschaben is offline
post #6 of 20 (permalink) Old 03-07-2011, 02:20 PM
Amazon.com: Kreg PRS3040 Precision Router Table Insert Plate Levelers: Home Improvement
post #7 of 20 (permalink) Old 03-07-2011, 08:46 PM Thread Starter
First Name: Gail
Thanks all. I chatted with a friend at work who asked why I hadn't tried backing up with nuts. Well, once I'm leveled, why not? If I have some handy, I'll try that. Otherwise, nail polish. Great idea. Should do the trick.
woodburl is offline
post #8 of 20 (permalink) Old 03-08-2011, 01:34 AM
Default I was wondering about this...
Thanks for this info. I just today received an Incra plate and was putting the adjusting screws in and noticed they got very snug before they went in very far. I backed one out and it had slivers of aluminum on it. Since they need to protrude from the bottom I removed them and started them from the bottom, but of course with the same results. But I believe if I had threaded them all the way through from the top the hardened steel screw would have "cleaned up" the mis-matched threads in the aluminum and they would be loose. It would have been nice if the instruction sheet had made mention of this since it is a (AFAIK) unusual way of locking a thread.
ArTrvlr is offline
post #9 of 20 (permalink) Old 03-08-2011, 12:01 PM
You're right. Those should really be installed from the bottom, drive end first and "unscrewed" through the plate until level is achieved. I have a couple that require the loctite treatment.
John Schaben
jschaben is offline
post #10 of 20 (permalink) Old 03-09-2011, 11:38 PM
Vendor Account
RT1000's Avatar
First Name: Joe
I am curious on what they would use to make a 1/4 x 27 tpi threaded hole.
And i like the Idea of using nail polish. I tell all my customers to use locktite (not green)
I have herd of this before I will have to check myself to make sure it works
RT1000 is offline
craftsman router table screws reds_21 Table-mounted Routing 8 12-21-2012 08:00 PM
Two eyes, ten fingers and a few loose screws (gotta start somewhere) precognito New Member Introductions 7 03-18-2010 02:24 AM
Torx and not so Torx screws sourdough Tools and Woodworking 2 02-01-2010 04:48 AM
Screws won't fit Router Plate don1 General Routing 24 02-16-2009 06:29 PM
