How to use a jointer fence? - Router Forums
post #1 of 7 (permalink) Old 10-07-2004, 09:39 PM Thread Starter
First Name: Garry
Default How to use a jointer fence?
Hi,
I am using a jointer fence of polyethylene. The out-fence is 1 mm proud of the in-fence and I am using a 19 mm bit. It seems that the jointed face is concave and that I am removing more from the middle of the wood than from the ends.
When there is sufficient past the bit I keep the pressure against the out-fence and down and release the pressure from the in side of the bit. As more goes past the bit I spread the pressure along the out-fence. What am I doing wrong?
Any help would be appreciated.
garryjc is offline
post #2 of 7 (permalink) Old 10-07-2004, 10:44 PM
reible's Avatar
Are you sure the bit and the fence are aligned?
Ed
reible is offline
post #3 of 7 (permalink) Old 10-07-2004, 11:06 PM
It is possible that the out-fence is not parallel with the in-fence. I had that happen to me.
Aaron
The speed of light travels faster than the speed of sound, that's why people appear intelligent until they open their mouth ...
Spacemanspiff is offline
post #4 of 7 (permalink) Old 10-07-2004, 11:11 PM Thread Starter
First Name: Garry
Aaron
The fence has been checked and is accurate. It is 50 mm thick and 40 mm high.
Garry
garryjc is offline
post #5 of 7 (permalink) Old 10-07-2004, 11:21 PM
reible's Avatar
Garry
If the bit is high to the out-feed this is what happens. I would check again the out-feed to bit alignment. If you are using a flushtrim bit make sure the bearing is just isolated in relationship to the out-feed. This is the same thing that happens to jointer/planners (machines).
Ed
reible is offline
post #6 of 7 (permalink) Old 10-07-2004, 11:56 PM Thread Starter
First Name: Garry
Ed
Sorry, I should have said that I had isolated the bearing to the out-feed.
Garry
garryjc is offline
post #7 of 7 (permalink) Old 10-08-2004, 12:38 AM
reible's Avatar
Garry
If you have the time, take a scrap piece of wood and feed it along the fence so that it cuts off the 1 mm then when the wood is just maybe 50mm past the cutter pull it away and turn off the router.
Take the wood and move it to the in-feed and slowly slide it by the bit until it is almost at the end of the cut. If you have a feeler gauge try sliding it between the out-feed and the stock (sheet of paper will do if you don't have a gauge). There should be no space between the stock and the out-feed while holding the stock against the in-feed side only. If this checks out try again but this time go 75 or 100 mm down the way.
If all that checks out You might look for something moving when you apply pressure, look for something flexing........ Maybe make your self some feather boards or if you have some use them, maybe you are just a little to strong for fence......
Ed
reible is offline
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
CMT Industrio Router Table System (orange cabinet) Ladd Table-mounted Routing 51 03-08-2010 11:29 AM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
