Triton 3/14 Hp modifications - Router Forums
post #1 of 4 (permalink) Old 03-21-2011, 11:31 AM Thread Starter
First Name: Ray
Default Triton 3/14 Hp modifications
All,
While I am awaiting the arrival of my new Triton 3/14 HP router and finishing up the new table to install it in, I have a question: Are there any recommended modifications to be done to the (new model w/steel gear) to make it more user freindly as a table mounted router? TIA
Rayl is offline
post #2 of 4 (permalink) Old 03-21-2011, 08:30 PM
The Triton works great for a table mounted router. Just mount it according to instructions.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 4 (permalink) Old 03-21-2011, 08:54 PM
metzgeri's Avatar
First Name: Tim
Yup,
Paint 'er camo, slap some Yosemite Sam mud flaps on 'er and stick a Dixie flag on the side!!!
Seriously, though, I wouldn't "mod" it out just yet. Any permanent mods will void the warranty, as I'm sure you're aware of and, with any new purchase, warranty is important. The only thing that is recommended is to remove the plunge spring to mount it in a table.
When you do mount it, make sure you position it to your liking where the controls are comfortable for you (i.e. being a lefty/righty, which side for coarse plunge depth, which side to power on, etc...). Especially be concerned about where the above table fine adjustment is. For me, I tend to go under the table and use the router's knob to fine adjust. If you prefer above table, then be aware that the hole needs to be closest to the operator and not towards the rear (as mine is) so that the fence doesn't block it. The last thing you want is to set the fence and then have to constantly remove it, raise the bit, then reset the fence.
metzgeri
Words to be raised by: "I am I plus my circumstances"
Words to Live by: "Proper Planning Prevents Piss Poor Performance"
Words to die by: "Arbeit Macht Frei"
metzgeri is offline
post #4 of 4 (permalink) Old 03-21-2011, 09:10 PM
Exclamation
Originally Posted by Rayl View Post
All,
Ray,
No mods are required. If using table mounted, Triton recommend you remove the spring and they show how to do that in the manual.
Sydney, Australia
jw2170 is offline
Triton MOF001 worm gear 2jawchuck General Routing 12 11-18-2012 05:54 PM
Important information regarding TRITON harrysin Lobby 1 01-05-2010 08:08 PM
Triton Router & Router Raizer kenrg Table-mounted Routing 18 11-24-2009 12:53 PM
On-going saga of Triton crquack General Routing 5 11-17-2009 12:10 PM
Problems with Triton in Table. hgporter Table-mounted Routing 4 06-12-2009 11:18 AM
