Drawers - Router Forums
post #1 of 15 (permalink) Old 03-23-2011, 12:34 PM Thread Starter
Default Drawers
Hi. I'm building some kitchen cabinets, and I'm looking for suggestions as to what to make the drawers out of. The drawer fronts will be Red Oak. I have a drawer lock bit, and I'm planning to use that for all of the joints. I'm not keen on using 1x pine for the back and sides because it's hard to get flat, straight lumber, and I don't think they need to be 3/4 in. thick. Also, what would you use for the bottoms?
madcitymike is offline
post #2 of 15 (permalink) Old 03-23-2011, 01:27 PM
walowan's Avatar
First Name: Michael
sides can be 1/2" MDF bottom 1/4" or 1/2" ply depending on size...
walowan is offline
post #3 of 15 (permalink) Old 03-23-2011, 02:03 PM
First Name: Richard
Most big box stores and lumberyards have popular in good straight boards in 1/2" and it is harder than pine and easy to work with and takes paint well if you decide to do that, plus useing it in a kitchen it won't swell like MDF if it get's wet. Then 1/4" prefinished plywood or hardboard for the bottoms.
Racer2007 is offline
post #4 of 15 (permalink) Old 03-23-2011, 03:34 PM
1/2" Baltic Birch type plywood is pretty much industry standard for nicer cabinets, unless you go with solid poplar.
1/4" or 1/2" will work fine for the bottoms.
Tempest is offline
post #5 of 15 (permalink) Old 03-23-2011, 05:23 PM
walowan's Avatar
First Name: Michael
Yeah, poplar is a good choice for drawer sides also. I just said MDF becuse that's wht we used in the custom cabinet shop I worked at. For the higher end cabinets we just ordered premade drawers....
walowan is offline
post #6 of 15 (permalink) Old 03-23-2011, 05:36 PM
woodjoiner's Avatar
First Name: Leon
Hi, Mike
I would use a 1/2" cabinet grade sanded plywood, I'm not sure axactly the number of plys it has but I think its somewhere around 6 plys and you can find it at most home improvement stores. Hope this helps.
woodjoiner is offline
post #7 of 15 (permalink) Old 03-23-2011, 06:02 PM
BigJimAK's Avatar
poplar is good... my wood store (a custom cabinetmakers supply) brings in some 5/8" clear soft maple for this also, for those who prefer the maple look.
BigJimAK is offline
post #8 of 15 (permalink) Old 03-23-2011, 11:56 PM
The only ply I would recommend is Baltic Birch ply if you want ply drawer boxes. I prefer to use hard maple machined down to 5/8" with 1/4" maple ply with mdf core for the bottoms. !/2" bottoms for drawers that will hold items like pots & pans.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #9 of 15 (permalink) Old 03-24-2011, 11:17 AM Thread Starter
Thanks for all of your suggestions. Very helpful info. Big Box did not have poplar in 1/2 inch. Looks like it will be Birch. Thanks again.
post #10 of 15 (permalink) Old 03-27-2011, 12:11 PM
JBS
Great info. Thanx for all the tips as well. I need to make few boxes to finish out the garage cabinets. =]
JBS is offline
Kitchen cabinet make over (new doors / drawers) Nickbee Show N' Tell 32 03-24-2013 04:26 PM
Sticky drawers help Schechner The Finishing Touch 12 12-02-2009 02:12 AM
Making drawers with pocket screws S Bolton Jigs and Fixtures 14 12-28-2008 08:15 PM
Drawers I needed mit-ch Woodturning and Lathes 9 02-08-2008 09:35 AM
making drawers - material? reikimaster Tools and Woodworking 4 11-05-2007 10:04 AM
