Any suggestion for an entry level router table top? - Router Forums
post #1 of 19 (permalink) Old 03-23-2011, 12:08 PM Thread Starter
First Name: will
Default Any suggestion for an entry level router table top?
I just bought my first router two weeks ago, a Craftsman router. Now I am looking for a table. I can build a stand (cabinet) for the router by myself, but it is out of my depth to build a table top. Any suggestion (product link) for the top? What accessories do you think are the most useful?
I am a woodworking beginner and don't the router frequently, so the very professional one, like Incra, may not be my target.
volunteers is offline
post #2 of 19 (permalink) Old 03-23-2011, 12:43 PM
couple pieces of mdf glued together makes a nice flat table top. cut a hole to fit an insert plate and you are good to go. cant really get a whole lot easier
Mike Gager is offline
post #3 of 19 (permalink) Old 03-23-2011, 01:07 PM
Hi Will
About one for 125.oo bucks
T10432 Router Table with Stand
post #4 of 19 (permalink) Old 03-23-2011, 01:10 PM
First Name: Richard
Mike is right it is really easy to build the top. If you think you can handle the cabinet then there should be no problem with the top. Check out the thread at the top of the fourm here to see one way to it.
http://www.routerforums.com/table-mo...ing-plate.html
Racer2007 is offline
post #5 of 19 (permalink) Old 03-23-2011, 02:41 PM
A wide melamine coated shelf from a big box with a hole in it.
Tempest is offline
post #6 of 19 (permalink) Old 03-23-2011, 03:32 PM
kp91's Avatar
First Name: Doug
The oak park top is a decent one, Oak Park Enterprises Ltd.: Catalogue,
My first table top was a kitchen sink cut out. You could always swing by your local Habitat for humanity store and pick up a bathroom vanity base and a scrap countertop for starters...
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #7 of 19 (permalink) Old 03-23-2011, 04:36 PM
Honored Member
First Name: pat
A thin piece of good MDF can suffice if the table is well stressed. More on the whole picture.
Quillman is offline
post #8 of 19 (permalink) Old 03-23-2011, 04:45 PM
woodjoiner's Avatar
First Name: Leon
A sink cut out is a good choice, the laminate top will last a long time and moisture won't effect it.
woodjoiner is offline
post #9 of 19 (permalink) Old 03-23-2011, 04:56 PM
Default do it yourself and learn
I agree with the others here, a top is very simple to make, certainly no more difficult than making a cabinet.
Don't think you have to get it exactly right the first time. Everybody seems to like different set-ups on their table and there is no way you will know what you like, or don't like, until you try. The hardest part will be the cutout for an insert (if you go with an insert), but it will be good practice learning to use your new router. Or you could just bolt the router to the underside of the top, many say that is the way to go anyway.
For your first try, don't even worry about what you have read about a laminated, multi-layer, super-flat, super-slick show-off top. Just make something to hold your router and see how you like using it. Learn by doing!
ArTrvlr is offline
post #10 of 19 (permalink) Old 03-23-2011, 08:28 PM
woodjoiner's Avatar
First Name: Leon
I couldn't agree more with the comment that john made the quote that "you learn by doing couldn't be more true. Just like practice makes perfect. To add to the last post you can easily make a template or guide to make a router plate fit like a glove.
Anyone converted a table saw to router table? OneStaple Table-mounted Routing 56 08-27-2019 03:53 PM
Router table build is underway - w/pics 30coupe Table-mounted Routing 83 03-17-2014 07:28 PM
Took the new router table top for a spin. 30coupe Table-mounted Routing 7 01-26-2011 12:26 PM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 09:51 AM
Kreg Bench Top Router Table cummiskeyjames Table-mounted Routing 3 01-18-2009 05:00 AM
