Tear Out - Router Forums
post #1 of 12 (permalink) Old 04-02-2011, 09:41 AM Thread Starter
thevirg's Avatar
First Name: Virgil
Default Tear Out
To combat tear out at the end of a piece, I often feed left to right and climb cut just a bit of the material. I then feed it right to left to route the rest of the material. It seems to work well for me
Is this a bad tecnique for any reason?
Virg.
thevirg is offline
post #2 of 12 (permalink) Old 04-02-2011, 10:03 AM
Virg.
Hi Virg - Not a method I would recommend right off the bat. If you do want to do it that way, I would recommend you do the climb cut LAST. ie. run your profile up to within, say, half an inch from the end and then feed that last half inch in backwards. Theory here is that if the bit does grab it, it will run out of material quickly. Doing the climb cut first gives the bit the whole stick to work with.
John Schaben
jschaben is offline
post #3 of 12 (permalink) Old 04-02-2011, 10:48 AM
Hi
DANGER, DANGER Will Robinson,, using a push block to support the wood and at the end of the pass works well for most, if you have stock with knots in it you can use the pocket way, that's to say side the bit into the edge of the stock and put in pockets so to speak, this will beak up the grain of the stock and stop the rip out..using the climb cut can be very tricky if you feel like you want to use it ,never cut deeper than a 1/8" deep cuts.
http://www.google.com/imgres?imgurl=...ed=0CC8Q9QEwBg
post #4 of 12 (permalink) Old 04-03-2011, 01:01 AM
"upgrade windows 95".......LOL
Where did you find that site, BJ
To combat tear out at the end of a piece, I would use a backer board.
Sydney, Australia
jw2170 is offline
post #5 of 12 (permalink) Old 04-03-2011, 05:39 AM
derek willis's Avatar
First Name: Derek
Of course you would, James, how else.
Derek
derek willis is offline
post #6 of 12 (permalink) Old 04-08-2011, 09:46 AM Thread Starter
thevirg's Avatar
First Name: Virgil
Smile
Thanks for your responses guys.
Virg.
thevirg is offline
post #7 of 12 (permalink) Old 04-08-2011, 09:52 AM
Hi James
Many still use win95, LOL and the 3.0 ver. of Windows.
Annoyances.org - Windows 95 Discussion Forum
post #8 of 12 (permalink) Old 04-08-2011, 11:53 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Cash registers here still use DOS !
istracpsboss is offline
post #9 of 12 (permalink) Old 04-08-2011, 12:18 PM
gav
Country: Croatia
First Name: Gavin
Peter, the ministry of interior (MUP) in Zagreb still use dos.
gav is offline
post #10 of 12 (permalink) Old 04-08-2011, 01:02 PM
Hi
I still use DOS for my POS software program (Champ Products for Cash Registers/bar code items )
Best method to band plywood without tear out Slomoe Router Bits - Types and Usage 8 02-26-2011 11:06 AM
a tear out problem loninappleton Table-mounted Routing 3 09-23-2010 08:39 PM
Baltic Birch Tear Out Ross Wigle New Member Introductions 7 01-06-2010 10:16 AM
jig for tear drop hole gabers Jigs and Fixtures 5 01-29-2009 02:56 PM
Katie Jig and tear out S Bolton Jigs and Fixtures 8 10-04-2008 04:24 PM
