Incra ls positioner - Router Forums
post #1 of 3 (permalink) Old 04-03-2011, 03:43 PM Thread Starter
First Name: JAMES
Default Incra ls positioner
Question for those of you familiar with this tool: The "Master Reference Guide" lists all the templates together with the bit type and suggested thickness for each template. Can one deviate from the stock thickness? For example, Box H shows a suggested thickness of 3/8". Can 1/2" or other stock thicknesses be use with this template?
EQUINOX400 is offline
post #2 of 3 (permalink) Old 04-03-2011, 04:21 PM
LexB's Avatar
First Name: Lex
I don't have my Master Reference guide in front of me, but if that's one of the templates for box joints, then yes, you can use thicker material. I've used 3/4-inch thick stock with a 1/4-inch straight bit to make box joints on my Incra LS-17 fence. Note that you cannot make a full-depth cut in one pass--you should not cut any deeper than your bit is wide, so in my case, I made three passes with the 1/4-inch bit to cut 3/4-inch deep (1/4-inch deep the first pass, then increased depth to 1/2-inch for the second pass, and 3/4-inch deep for the third pass.) Fortunately, the repeatability of the Incra system makes this easy. I could have used a different template and a larger bit, but I prefer the look of the thinner fingers.
LexB is offline
post #3 of 3 (permalink) Old 04-03-2011, 06:46 PM Thread Starter
First Name: JAMES
This is what I thought. Thank you for your prompt response.
Incra LS Positioner - How to allow for saw kerf? jhelminski Table-mounted Routing 9 09-28-2010 12:20 AM
dovetail router bits for incra positioner wintu Table-mounted Routing 14 06-03-2010 01:45 PM
need table for incra ls positioner. Alan M Table-mounted Routing 4 04-06-2010 06:18 PM
Router Table For Incra LS Positioner (25") Rutabagared Table-mounted Routing 5 06-24-2009 07:12 AM
Incra LS Positioner and Bosch RA1181 table thistlefly Table-mounted Routing 3 01-05-2009 06:58 PM
