Setting router depth - Router Forums
post #1 of 7 (permalink) Old 04-06-2011, 08:37 AM Thread Starter
First Name: Lloyd
Default Setting router depth
I have just bought a used Porter Cable router model 7538. I know with other routers you can set the bit depth on a router table from top. Can you do this with this model? I am also new to the plunge router.
Lloyd
lsessions is offline
post #2 of 7 (permalink) Old 04-06-2011, 09:14 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Lloyd
With a plunge router, any plunge router, to set the depth of cut sit the router on the work-piece and plunge 'till the bit touches the work-piece then lock the plunge. The depth of cut is now set between the foot and one of the anvils. The router is then unlocked and ready for plunging to the pre-set depth.
Harry
harrysin is offline
post #3 of 7 (permalink) Old 04-06-2011, 10:25 AM
HI Lloyd
Not the norm BUT with just a little bit of rework you can make it so..
You will need to remove and replace the STOP rod bolt with the two nuts on it and replace with a FULL thread Allen cap screw or a spring center bolt that is HT and full thread but with a screw driver slot head, or buy the kit below and use the parts to make a lift kit.
Amazon.com: Router Raizer RZ100 Precise Router for Depth Adjustment: Home Improvement
Router Raizer
Lloyd
post #4 of 7 (permalink) Old 04-06-2011, 10:15 PM
G’day Lloyd
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #5 of 7 (permalink) Old 04-07-2011, 01:10 PM Thread Starter
First Name: Lloyd
Thanks for all that replied. I found that Porter Cable sells an height adjustment knob # 75300 for this model router
Looks like it will work.
Thanks again
Lloyd
post #6 of 7 (permalink) Old 04-07-2011, 01:47 PM
Hi Lloyd
You must have the fine adjustment device on the router (7538) and on this one it's not in place..#75301, like is on the below .
But than I could be wrong..
http://www.amazon.com/Porter-Cable-7...1&sr=1-1-fkmr0
Amazon.com: Porter-Cable 892 2-1/4-Horsepower Router: Home Improvement
Thanks again
Lloyd
post #7 of 7 (permalink) Old 04-10-2011, 08:21 PM
sparetime's Avatar
First Name: Tim
Default Wow
Thanks for the pics and advice. Read this post last night and used the trick today and it worked perfectly.
sparetime is offline
I think my old router nearly killed me! peacefrog General Routing 23 01-26-2014 11:36 AM
Sears Plunge Router Model 315.275110 Wally99 Table-mounted Routing 3 12-24-2008 06:39 AM
