New router cabinet ventalation ? - Router Forums
post #1 of 3 (permalink) Old 04-06-2011, 07:08 PM Thread Starter
First Name: Tim
Default New router cabinet ventalation ?
I'm in the middle of building my first router table. Previous was in table saw extention table. That said I want to know how to determine how much open vent area I need in the table for good dust colection and proper cooling of router The cavity it will be housed in is 23" deep 17" high and 15 1/2" wide. Elu 3339 router hung with a Unilift 4" dust collection on lowest area of back panel. Do the vent's need to be in the front or could they also be on the back of the cabinet ? The sides are not an option as the compartment is flanked with drawers on both sides.
Tim
Tim Chase is offline
post #2 of 3 (permalink) Old 04-06-2011, 07:33 PM
Hi Tim,
I would mount them in front for good crossflow in the space.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 3 (permalink) Old 04-06-2011, 08:08 PM
First Name: Kerry
I would be inclined to put them in front as well. I would equal, or approximate the draw to be the same as the exhaust. So if you have a four inch hole in the back, I would make the vents up front roughly the same in area up front. If you have an access door you can experiment before you drill. Throw a few handfuls of sawdust in the router compartment and crack the door a couple inches and then turn on the DC and see what happens. Try this a few times to see what works best. It really isn't that critical or scientific. If your in the ballpark... it will work. Good luck!
2bigfeet is offline
How to put the router table top to the cabinet? volunteers Table-mounted Routing 15 02-24-2012 10:06 AM
New router cabinet DPLRBruno Show N' Tell 17 04-07-2009 02:28 PM
My New Router Cabinet Birch Table-mounted Routing 5 03-09-2009 08:37 PM
