what is the problem of making mortise with table router? - Router Forums
post #1 of 5 (permalink) Old 04-08-2011, 01:33 PM Thread Starter
First Name: will
Default what is the problem of making mortise with table router?
I don't make many mortises and I just used my chisels every time. After reading former posts here, JessEm ZipSlot mortise mill looks cool, but I really don't have budget to buy a new tool for mortises.
Now I am building my first router table. I did see people use table router to make mortise in a video from New Yankee Workshop Online.
Is this a practical way to make mortise? what are the potential problems? Thanks.
volunteers is offline
post #2 of 5 (permalink) Old 04-08-2011, 01:55 PM
Hi Will
" practical way to make mortise?" = Yes,,,you can make the jig below for peanuts, with some scrap stock you have around the shop, it will do both types (floating and the standard way ) by taking off some bearings you have on some of your bits and a bit of 1/4" thick MDF or some plastic stock for the base plate you will have a good setup.
http://www.routerforums.com/jigs-fix...ge-router.html
post #3 of 5 (permalink) Old 04-08-2011, 03:52 PM
Honored Member
First Name: pat
In my view, the router table is not the place to make mortices.
Some mortices, open ended e.g., are of less risk but at some risk nonetheless.
The nature of using a stationary router for morticing assumes straight stock, square and flat. Moreover, the fence and table surface must be equally flat and defect free.
If your QC is <100%, you may feed a cork-screwed stick into the cutter at any time.
Now this is for open ended cuts. As the cut proceeds the work may self feed as it "finds" itself along the fence. Anything unexpected like that can put your hands in the proximity of the cutter spontaneously and eat you up. So you can have problems with 1/2-blind mortices.
Now whence cutting a blind mortice your risk has doubled. You can't see the cutter and in the event of a self feed the work is torn from your hands and the cutter has a field-day. Neither scenario is worth a minute in the ER. Better you concentrate on building fixtures for hand routig mortices with a plunge router.
Quillman is offline
post #4 of 5 (permalink) Old 04-09-2011, 02:39 AM
gav
Country: Croatia
First Name: Gavin
Hi Will
Bob, are you sure you meant to say this about making mortises on the router table ?
In other threads you say the complete opposite.
Router hand held with a jig is the most practical safe way to do mortises.
gav is offline
post #5 of 5 (permalink) Old 04-09-2011, 09:30 AM
Hi gav
Router table ???? I said the plunge router way is the best see link.
Help with router and table djonesax Table-mounted Routing 31 08-27-2012 06:10 PM
Do I need a router plate for my new table? Ryan's Dad Table-mounted Routing 16 09-16-2011 06:53 PM
New router, need table, building dovetail cabinets santana157 General Routing 7 02-02-2009 11:34 PM
Question with making a router table edbd1100 Table-mounted Routing 8 03-06-2006 09:56 PM
