large radial baseboards - Router Forums
post #1 of 5 (permalink) Old 04-09-2011, 09:51 PM Thread Starter
Default large radial baseboards
I need to make some large radial baseboards to trim the intersection of a hardwood floor and a vertical tile step. The baseboards need to be 1/2" thick x 2" wide and have a curveature of about 4'. Because of the curve I can't use a straight fence to trim cut after the scroll saw cut out operation. How do I configure the fence to trim to a large curve? Mike
lmikekelly is offline
post #2 of 5 (permalink) Old 04-10-2011, 05:25 AM
derek willis's Avatar
First Name: Derek
You will need to rout by hand and use a pointed fence so that only the point is in contact with the timber at any time.
Derek
derek willis is offline
post #3 of 5 (permalink) Old 04-10-2011, 07:16 PM Thread Starter
Thanks Derek for the advice. I appreciate your attention to my problem - mike
post #4 of 5 (permalink) Old 04-10-2011, 07:41 PM
Hi Mike, if I understand this right, the workpiece is 1/2" high, about 2" deep and X wide with about 4 ft of it in a curve. All you really want to do is take off the saw marks. Any chance of making kind of a guide surface out of a semi-flexible material such as hard board? I'm thinking about a 1/2" wide strip of 1/8" hardboard fixed on edge along the cutline. If you can rig that then you could do it on the table using a bearing guided flush trim bit. Just a thought
John Schaben
jschaben is offline
post #5 of 5 (permalink) Old 04-11-2011, 12:03 AM Thread Starter
Thanks John, I think that might work. I'll give it a try. My problem now is transfering the step contour, which is an approx. 6' rad. to a piece of 1/8' thick material that i can use as a templete. Thanks again, mike
Dewalt Radial arm saw jetpilot Tools and Woodworking 8 07-12-2010 02:47 PM
radial drill press experiences pls. allthunbs Tools and Woodworking 6 07-03-2010 06:08 AM
Rockler large blank plate bushing insert..... Duane867 Table-mounted Routing 25 12-07-2009 06:36 PM
radial arm saw KENNETH KIDWELL Lobby 2 05-09-2006 09:10 PM
