A no-no? - Router Forums
post #1 of 18 (permalink) Old 04-12-2011, 04:34 AM Thread Starter
matt1710's Avatar
Country: New Zealand
First Name: Matthew
Question A no-no?
Hi
I was playing around with my RT last night and decided to use it to cut a shallow rebate in the bottom of a small box, so that the bottom (approximately 4mm thick) could sit flush in the recess. I set the RT up so that the stock (about 6mm thick, 80mm x 300mm) would pass between the bit and the fence. I used my feed direction rule (ie palm up, make a 'gun' with thumb and index finger : thumb points at fence, index finger points to feed direction) so established the feed direction. Being a RT newbie, I put two feather boards on (one vertical, one horizontal) and used a push stick The stock didn't feed smoothly at all - it almost "jumped" through in short bursts, and when I examined the cut, you could see if wasn't a nice smooth cut. I was puzzled as thought I had done it properly - although I possibly removed too much material at once. Anyway, here's what I did - could someone please give me some feedback?
First attempt:depicted in Diagram A
Looking at it now, it seems that I was feeding with the bit rotation - which is wrong (correct?) - but why did it jump through, and not shoot away? Maybe because the stock was being squeezed between bit and fence - or maybe the feather board slowed things?
Second attempt : depicted in Diagram B
Again, looking at it now - this appears the right feed direction - but this produced a worse cut than Diagram A's setup - in fact the stock took off (albeit slowly) and heading off away from the fence, chewing though the lower edge of the box's side.
Were both of these attempts incorrect?? Should I not be placing the stock between the fence and the bit??
So I made two more diagrams (C & D) - I haven't tried these yet. If I indeed shouldn't have been placing the stock between the fence and the bit, then Diagram C looks like the one I should use - correct?
Matthew
matt1710 is offline
post #2 of 18 (permalink) Old 04-12-2011, 05:37 AM
Cassandra's Avatar
First Name: Cassandra
Hi Matthew:
A: bad
B: bad
C: proper
D: risky
General rule: Do not trap workpiece between bit and fence. That's asking for trouble! More like begging, than asking.
D is a climb cut. Generally a bad idea, but sometimes used. If used, make minimal cut (depth and width.)
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #3 of 18 (permalink) Old 04-12-2011, 05:51 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I can't improve on what Cassandra has said other than to admonish you my friend, I really thought that you were by this time fully familiar with the basics of routing.
Harry
harrysin is offline
post #4 of 18 (permalink) Old 04-12-2011, 06:21 AM Thread Starter
matt1710's Avatar
First Name: Matthew
Ah - I knew it! At the time it seemed the right thing to do (to be fair to myself, I've only used the RT a handful of times, and don't recall reading anywhere that feeding between the fence and the bit was a BAD idea) however when the cuts came out poorly and jumpy, I stopped work.
I must have had all my safety gear working well in order to survive those blunders without loosing a digit!!
I'll give it a try when I next get time...this time using method C!!
Thanks for your advice.
matt1710 is offline
post #5 of 18 (permalink) Old 04-12-2011, 09:30 AM
walowan's Avatar
First Name: Michael
For doing what you describe, I've found the best way to do it is with a handheld router.
walowan is offline
post #6 of 18 (permalink) Old 04-12-2011, 09:44 AM
HI
I will 2nd this post but add ALWAYS use a push block, that will let you hold the stock down and push it forward...big or small stock..push block it..
Originally Posted by Cassandra View Post
Hi Matthew:
A: bad
B: bad
C: proper
D: risky
Cassandra
post #7 of 18 (permalink) Old 04-12-2011, 11:02 AM
Hi Matthew:
A: bad
B: bad
C: proper
D: risky
Cassandra
Hi Matthew,
Glad you didn't get hurt. I agree with Cassandra also.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #8 of 18 (permalink) Old 04-12-2011, 11:06 AM
Hi Matt - I can't really add anything to what has been said. You correctly deduced that method C is the best. I would like to note that sometimes you can trap stock when it's not all that obvious you are going to do so. For example, If you want to make a dado a bit wider, you need to adjust the fence back so the bit would be taking off the edge closest to the front of the table. If just taking of a few thousands, it always felt natural to move the fence toward me until the first time I tried it and the thing ripped the stock out of my hand and did it's level best to put a hole in the far wall. Good luck
John Schaben
jschaben is offline
post #9 of 18 (permalink) Old 04-12-2011, 07:20 PM
First Name: Jerry
"C" is correct as the stock moves against the bit direction and the stock is not between the bit and fence.
jsorrell is offline
post #10 of 18 (permalink) Old 04-12-2011, 07:27 PM
Marco's Avatar
Default Had not thought of it but glad you mentioned it
Originally Posted by jschaben View Post
............. I would like to note that sometimes you can trap stock when it's not all that obvious you are going to do so. For example, If you want to make a dado a bit wider, you need to adjust the fence back so the bit would be taking off the edge closest to the front of the table. If just taking of a few thousands, it always felt natural to move the fence toward me until the first time I tried it and the thing ripped the stock out of my hand and did it's level best to put a hole in the far wall. Good luck
Thanks for bringing that up..... hopefully I will remember that before I try to widen a dado or at worst before I hurt myself!!!
[BďItís not a mistake, itís a design featureĒ][/B]
Marco is online now
