Rout edge of circle on the table? - Router Forums
post #1 of 8 (permalink) Old 04-14-2011, 09:21 AM Thread Starter
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Default Rout edge of circle on the table?
Hi Guys
I need to rout a round over on the edge of a couple of bar stool tops. Can I push these through my router table or do I need to go the hand held route?
The tops are 400mm diameter and 19mm thick.
Thanks.
cagenuts is offline
post #2 of 8 (permalink) Old 04-14-2011, 09:33 AM
gav
Country: Croatia
First Name: Gavin
With a bearing guided round over bit, you should be able to do it on the table.
A starting pin would make it safer, as in this pic, although I don't recommend getting your fingers that close to the cutter.
Might actually be easier ,safer and quicker hand held. Just use some double sided tape to stick it down to the bench and around you go.
gav is offline
post #3 of 8 (permalink) Old 04-14-2011, 11:41 AM Thread Starter
cagenuts's Avatar
First Name: Hilton
Ah thanks for the reply. I just need to check if I can insert a pin in my Triton router table.
Interesting what you say though about it being safer hand held. I always tend to favour the table over my hands because I've always thought it was safer that way (limited to smallish items of course).
Keep well.
cagenuts is offline
post #4 of 8 (permalink) Old 04-14-2011, 11:55 AM
Hi Hilton
Some of the Triton router tables have a place for the pin but some don't if not just use a 1/2 Fence, it can be just a simple block of plywood (12" x 18" works well) clamped to the table in two points on the table, and just to right and back a little bit of the router bit just like a pin..but much safer way.
Keep well.
post #5 of 8 (permalink) Old 04-14-2011, 12:11 PM
Hi Hilton,
Either way is easy & simple job if bit has bearing.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #6 of 8 (permalink) Old 04-14-2011, 03:51 PM Thread Starter
cagenuts's Avatar
First Name: Hilton
Thanks guys, just need to check if my bot has a bearing.
cagenuts is offline
post #7 of 8 (permalink) Old 04-14-2011, 09:36 PM
It could be done without a bearing too. You just have to set the fence depth so that the radius of the circle only fits in just enough to do the roundover.
post #8 of 8 (permalink) Old 04-14-2011, 10:51 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
[quote=cagenuts;232353]Hi Guys
Thanks.[/quote
I find this to be the fastest yet safe method to roundover or fancy edge a disc.
Harry
harrysin is offline
New Router Table flemingj1122 Table-mounted Routing 13 05-19-2012 03:02 PM
Ryobi Intermediate table ..bushings??? rbevz Table-mounted Routing 5 02-24-2011 04:43 PM
Need to rout a rebate on a small frame - table or hand-held? cagenuts General Routing 5 02-08-2011 09:29 PM
Circle Jig for table router nzgeordie Jigs and Fixtures 4 11-22-2006 09:00 AM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 09:15 PM
