Climb cut - Router Forums
post #1 of 6 (permalink) Old 04-21-2011, 09:34 PM Thread Starter
First Name: Al
Default Climb cut
Hi members. As a beginner in routing it seems that I am having to develop a new vocabulary. I am finding words used in routing that seem to mean something different in everyday life. I hope you will bear with me if I ask over time, about some words commonplace to you but a mystery to me. In simple language what is a climb cut. Oldrusty
oldrusty is offline
post #2 of 6 (permalink) Old 04-21-2011, 09:46 PM
Honored Member
First Name: pat
Practically: A cut wherex the work, unclamped, may shoot away from you & against the nearest wall. The router is fed in the natural direction of the cutter.
Clean cuts but some loss of control to be expected and, perhaps, injury. A much more severe reaction occurs on the router table.
Quillman is offline
post #3 of 6 (permalink) Old 04-21-2011, 09:50 PM
Hi oldrusty
That's when the bit wants to Climb over the stock the norm..in short you running the stock the wrong way by the bit.. But it has a plus side also ,that's when you want a nice clean cut like on plywood.., the lumber will be pushed back into the slot keeping the rip down to a min..but not to be use by the novice router user the norm.....
Just a note ..it's just about always safe to do it with a hand router because you have the mass of the router doing the work for you but the bit will want to push the bit back from the stock the norm..
post #4 of 6 (permalink) Old 04-21-2011, 10:47 PM
Cassandra's Avatar
First Name: Cassandra
Hi:
The attached PDF shows the basic difference, in forces, between the normal cut and the climb cut.
In the normal cut, the router bit is drawn into workpiece by the force developed by the cutting edges on the workpiece. On the router table (as shown), the workpiece is drawn towards the fence. Also, the cutter applies a force on the workpiece in the opposite direction than the feed direction.
In the climb cut, the router bit tries to "climb" out of the workpiece. On the router table, the workpiece is being forced away from the fence. Also, the cutter applies a force in the direction of the feed direction.
This is what creates the danger for the climb cut. The bit moves the bit in the direction of the feed direction -- usually this means the worker has little control over the feed speed. At the same time, the router bit is trying to stay on the edge of the workpiece, thereby setting the situation where the cutting edges basically kick the workpiece along in the feed direction -- and out of the worker's control.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #5 of 6 (permalink) Old 04-22-2011, 11:29 AM Thread Starter
First Name: Al
Hi members. Thanks for the info on climb cuts. I can see how dangerous it could be. Oldrusty
oldrusty is offline
post #6 of 6 (permalink) Old 04-22-2011, 02:56 PM
HI
It's very safe if you use the right equipment on your router table.
The Board Buddies only let the stock go one way so to no danger of the stock taking off like a rocket..
Just a note,,, you can also add a power feed motor to your router table that works the same way but it's not cheap also from Grizzly.
4 members will jump in and tell you it can't be done but I will tell you it can be and I do it from time to time.
Grizzly.com® -- Search Results
G2372 Board Buddies® For Radial-Arm Saws - Orange
http://www.grizzly.com/products/Baby-Power-Feeder/G4173
slidng on the rods allthunbs General Routing 11 04-07-2011 05:26 AM
Climb cut on a 45 lock miter bit? Finleyville Router Bits - Types and Usage 13 02-20-2011 10:49 PM
Weatherwatch. derek willis Table-mounted Routing 11 02-14-2009 03:41 AM
Up Cut... Down Cut... Joe Lyddon Router Bits - Types and Usage 2 09-10-2006 06:21 PM
Welcome to "Show N' Tell" Mark Show N' Tell 0 08-17-2005 04:55 PM
