Fence location relative to the bit centerline - Router Forums
post #1 of 5 (permalink) Old 04-26-2011, 10:34 PM Thread Starter
First Name: Tim
Default Fence location relative to the bit centerline
I’m working on a fence for my router table. I have a setup where I have 3 different ranges of forward and aft adjustment of 2 7/8” each, that are controlled by using a dovetail machine slide as seen here (Slides ).
My question is for the most used range where should I start. I am thinking of setting this up with 1.0” adjustment in front of the bit and 1 7/8” behind the bit for my first range adjustment. I can then change the pin location and add 2 more working ranges to the rear of the bit of 2 7/8” ea. What range would be the best for the 1st range fore and aft of the bit? thanks
Slomoe is offline
post #2 of 5 (permalink) Old 04-26-2011, 11:01 PM
Hi Tim - Don't really need to overthink this. 1-1/2" ahead of the bit means you will need to be swinging a 3"+ bit to even touch the stock. Same for behind the bit for doing edge work. You need more travel behind the bit for doing dados and such in drawer/box sides for dividers and similar jobs. My guess would be 5-6" total travel would be plenty.
John Schaben
jschaben is offline
post #3 of 5 (permalink) Old 04-27-2011, 01:46 AM
Tim, why limit your fence locations with mounting slots? Simply clamp your fence in position with C clamps, this allows for infinite adjustments.
post #4 of 5 (permalink) Old 04-27-2011, 05:00 AM
derek willis's Avatar
First Name: Derek
Default Router fence.
Why don't you try a set-up similar to this, any increment can be made just by slackening the hold down bolts, and adjustng to the neccesary position required.
fence slide..jpg (286.8 KB)
Name:	fence slide..jpg
Derek
derek willis is offline
post #5 of 5 (permalink) Old 04-27-2011, 03:05 PM
Mike Wingate's Avatar
First Name: mike
I am limited to 3 positions with a small range of adjustment on my school Trend pro table. Not good. Always happy to use my selfbuilt extractor fence or the Incra, they are so much better.
Mike Wingate is offline
Spiral Bit Breaking in Router MikeMa Router Bits - Types and Usage 7 05-23-2010 11:28 PM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 06:38 PM
Making a Zero Clearance Fence for Drawer Lock Bit gerrym526 Table-mounted Routing 7 03-16-2010 10:08 AM
plywood glue bit keith Table-mounted Routing 4 03-03-2006 11:06 AM
Question about T-Slot Bit for router table fence. ryan.s Table-mounted Routing 5 05-02-2005 06:42 PM
