router speed - Router Forums
post #1 of 4 (permalink) Old 04-30-2011, 10:33 PM Thread Starter
First Name: Ellsworth
Default router speed
My PC 7539 has five different speeds on it. When I am making raised panels I am using a large cutter. What speed is best suited for large diameter bits?
ells
Ells is offline
post #2 of 4 (permalink) Old 04-30-2011, 10:39 PM
The slowest speed.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 4 (permalink) Old 05-01-2011, 12:18 AM
BigJimAK's Avatar
Large raised panel bits should also only be used with the router mounted in a table. I have the PC 7518 and use Sommerfeld's 3-1/2" raised panel bits and James is right-on about the slowest speed.
BigJimAK is offline
post #4 of 4 (permalink) Old 05-01-2011, 03:38 AM
Mike Wingate's Avatar
First Name: mike
It is all about periferal speed. Small cutters should run fast, large diameter cutters to run more slowly. I would use a large router in a table for this process.
Mike Wingate is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Modulated speed router problem. seanburns General Routing 6 08-19-2013 08:20 AM
Router Speed Control Switch fieldsd General Routing 6 07-05-2009 04:36 PM
Router Speed Guide CanuckGal Starting Off 9 12-25-2008 04:52 PM
