Porter Cable 690 and Rail and Stile router bit - Router Forums
post #1 of 11 (permalink) Old 05-29-2011, 04:01 PM Thread Starter
First Name: Kelly
Default Porter Cable 690 and Rail and Stile router bit
Is a Porter Cable router appropriate for use with a rail and stile router bit (Freud)? To little horse power? Too fast rotation?
KR
Kelly Rittgers is offline
post #2 of 11 (permalink) Old 05-29-2011, 04:36 PM
Here is a guide to use for different diameters. A variable speed router mounted in a table is usually recommended. The 690 has 1-3/4hp. More power for these bits will always help.
Router Bit Diameter Maximum Speed
Up to 1" 22,000 - 24,000 rpm
1" to 2" 18,000 - 22,000 rpm
2" to 2-1/2" 12,000 - 16,000 rpm
2-1/2" to 3-1/2" 8,000 - 12,000 rpm
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 11 (permalink) Old 05-29-2011, 05:01 PM
Hi KR
I use my 690 all the time with them but I do suggest a speed control box, you don't need the router running at 20,000 rpms.
10,000 rpm's is just right ..no need to cook the bits..
You are only taking off 7/16" of stock the norm and the 690 has the power easy to do that..
Router Speed Control
KR
post #4 of 11 (permalink) Old 05-29-2011, 05:05 PM
Honored Member
First Name: pat
In my view, the 690 does not have the Flywheel for cope/stick bits; it's on the threshold.
If you have a bigger machine use it. You will get less resonance and chatter.
Quillman is offline
post #5 of 11 (permalink) Old 05-29-2011, 06:53 PM
SteveMI's Avatar
First Name: Steve
Default Speed Control - HF
Hi KR
Bob,
How happy are you with the HF speed control? I just picked up a PC 690 and a Bosch 1604 that are single speed. I'd like to use a speed control with them.
I've never come across them in my local store, are they an online item only?
Steve.
SteveMI is offline
post #6 of 11 (permalink) Old 05-29-2011, 07:01 PM
They work just fine Steve. If the MI is for Michigan and you are near the "D" you are welcome to stop by and try your router on one before buying. I use one for my 1617 routers which have straight switches instead of the EVS control system.
post #7 of 11 (permalink) Old 05-29-2011, 07:38 PM Thread Starter
First Name: Kelly
Thanks for the help.
KR
post #8 of 11 (permalink) Old 05-29-2011, 07:58 PM
SteveMI's Avatar
First Name: Steve
Mike - I am downriver in Trenton.
Steve.
SteveMI is offline
post #9 of 11 (permalink) Old 05-29-2011, 11:37 PM
Hi Steve
" online item only? " = I think so I don't recalling seeing them in the outlet stores..
I like the speed control boxes, I use them all over the shop, at last count 5 in the shop...
If you don't like the HF stuff you can get one from MLCS, it's a bit higher in price..but with free shipping.
http://www.mlcswoodworking.com/shops...d_control.html
Originally Posted by SteveMI View Post
Bob,
Steve.
post #10 of 11 (permalink) Old 05-30-2011, 07:49 AM
BrianS's Avatar
First Name: Brian
Hi Steve. I've seen them in the Eureka Rd store in the past, but haven't looked for them recently so maybe they have made them online only.
Brian
(Origin uncertain)
BrianS is offline
Rail and style bits? Timberline Router Bits - Types and Usage 13 03-31-2011 01:01 PM
