Using Spiral Bits In a Table - Router Forums
post #1 of 9 (permalink) Old 06-07-2011, 11:15 AM Thread Starter
Ken Bee's Avatar
First Name: Ken
Default Using Spiral Bits In a Table
When using spiral bits in a table cutting box joints with a jig or just simple slots which type is best? Up cut or down cut, or will either work as well as the other? I want to order 3 different sizes, but really don't have the funds to order all 3 of each kind. I am going to order the Woodhaven Box Joint Jig today and at the same time order the bits also. Having said that as a way to conserve my funds will a straight bit work to cut the box joints? I understand they won't cut as well as a spiral bit, but if I can get by for a few weeks with my straight bits I will do so.
As usual all input is appreciated,
Ken
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #2 of 9 (permalink) Old 06-07-2011, 12:16 PM
Gene Howe's Avatar
First Name: Gene
Make sure the straight bit is a "plunge" type and it should work. Use a backer to prevent tear out.
When you do get a spiral, get the up cut. In the table, it'll pull the debris down and out of the cut.
Here is a site for some good, yet inexpensive spirals.
MLCS
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 9 (permalink) Old 06-07-2011, 02:40 PM
Here's a good buy on spirals, unfortunately looks like they only have 1/2" and 3/8" at the moment. They are liqudators and shopping with those guys is kind of a crap shoot.
John Schaben
jschaben is offline
post #4 of 9 (permalink) Old 06-07-2011, 03:01 PM
Gene Howe's Avatar
First Name: Gene
Hey John,
No linky
Gene Howe
Snowflake, AZ
post #5 of 9 (permalink) Old 06-07-2011, 03:51 PM
Originally Posted by Gene Howe View Post
Hey John,
No linky
Only got two brain cells left and sometimes they don't talk to each other
Spiral Bits : cripedistributing.com
John Schaben
jschaben is offline
post #6 of 9 (permalink) Old 06-07-2011, 04:54 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
That was my experience, too, but they got there in the end and their bits are excellent value. Mine were Bosch and American Vermont.
1 x Vermont American 1/2 Carbide Downspiral Router Bit 23217 (23217) = $16.00
1 x BOSCH 85913M 3/8" x 1-1 1/4" Up Spiral Router Bit (85913m) = $14.00
1 x Vermont American 1/2" Carbide Upspiral Router Bit 23212 (23211) = $16.00
1 x BOSCH 85631MC Edge Beading Carbide Router Bit USA (85631MC) = $8..00
As you say, they've nothing smaller at the moment.
Actually, after writing this, I did a quick check and they've some 1/4" shank, 1/8"dia x 1/2" cutting length ones at the moment
http://www.cripedistributing.com/ver...5a71c70b19d025
I'm indebted to list member Regis Leonard for kindly bringing mine over here and particularly for his calling specially to the Post Office on his way to the airport to pick them up, after Cripe had been slow dispatching.
Cheers
Peter
istracpsboss is offline
post #7 of 9 (permalink) Old 06-07-2011, 05:38 PM
Ken, the spiral up cut bits are for solid wood. Spiral down cut bits are for routing in plywood or veneers to help avoid tear out. Compression bits are for edge routing the whole thickness of plywood and veneers. (squeezes them together)
Odds are you will often use the up cut spirals so I suggest you buy all 3 sizes; 1/4", 3/8" and 1/2". Hold off on the others until you need them. You can use a straight bit to practice making box joints; they do a decent job but not as good as the up cuts.
post #8 of 9 (permalink) Old 06-07-2011, 05:59 PM
Phil P's Avatar
First Name: Phil
It's worth pointing out that compression spirals often leave a discernable witness line where the up- and down- shears meat. This needs to be sanded out on solid wood, MDF and most plastics
Regards
Phil
Phil P is offline
post #9 of 9 (permalink) Old 06-08-2011, 08:35 AM Thread Starter
Ken Bee's Avatar
First Name: Ken
Thanks for all the input guys. I did order the Woodhaven Box Joint Jig yesterday and after reading through this thread I also ordered a few spiral bits from Cripes as noted in the thread.
Strangely enough I still worked on a box joint jig I had started a week or so ago. All that is left is to drill a couple of holes and assemble it. It is also adjustable from 1/8" to 1". If I feel like it I will finish it today and see if it works.
Thanks again for all the input.
Ken
Ken Bee is offline
Router Table for Incra LS Positoner completed! Michael H Table-mounted Routing 35 03-19-2015 01:40 PM
for those who cant afford spiral upcut bits... Mike Gager General Routing 21 12-08-2012 05:00 PM
mlcs hss spiral bits gav Router Bits - Types and Usage 33 08-08-2012 11:15 AM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 10:51 AM
Spiral bits burn erco New Member Introductions 9 01-31-2009 02:31 PM
