setting the depth - Router Forums
post #1 of 3 (permalink) Old 06-08-2011, 02:35 PM Thread Starter
First Name: FLOYD
Default setting the depth
I am working on a metal clock. The plans tell me to set the router bit at 1/4in. I use a
try square set to 1/4 in. I brought the bit up tlo touch the square. Now am useing a router table. It didn't work it took off why to much . What is the peoper way to set the depth.?
Floyd
floyd226 is offline
post #2 of 3 (permalink) Old 06-08-2011, 03:09 PM
Hi
A quick way is to use a 1/4" drill bit..
Just roll the drill bit up to the router bit and put some scrap wood stock on the router bit, raise the router bit up until it's just lifts the wood stock up, lock the router bit and you are set to rock and roll..
Floyd
post #3 of 3 (permalink) Old 06-09-2011, 10:50 AM Thread Starter
First Name: FLOYD
Thanks bobi3 for the info. I will try that this afternoon. thanks again.
floyd
floyd226 is offline
Setting router depth lsessions Table-mounted Routing 6 04-10-2011 09:21 PM
adjusting depth how to figure out the right depth CFLfan Portable Routing 3 02-06-2010 07:22 PM
setting depth for plunge router mag_rules General Routing 8 02-03-2010 01:58 PM
PC 4212 Bit Depth zach Jigs and Fixtures 9 11-17-2009 12:24 PM
pc 890 series depth adjustment rabuckner General Routing 4 04-10-2005 02:20 PM
