Home built Router Fence - UHMWPE - Router Forums
post #1 of 22 (permalink) Old 09-11-2004, 01:24 AM Thread Starter
Smile Home built Router Fence - UHMWPE
First post - finding my way around
boomerang is offline
post #2 of 22 (permalink) Old 09-11-2004, 07:04 PM
Default Router fence?
Boomerang, what are all the screws for?
g-man is offline
post #3 of 22 (permalink) Old 09-11-2004, 08:33 PM
Server Administrator
Kevin's Avatar
First Name: Kevin
That looks interesting! What are the screws for that are on the end?
Kevin is offline
post #4 of 22 (permalink) Old 09-11-2004, 10:41 PM
Joe Lyddon's Avatar
First Name: Joe
My guess to the screws... for fine adjustments...
Have Fun,
Joe
Alta Loma, CA
www.WoodworkStuff.net
Joe Lyddon is offline
post #5 of 22 (permalink) Old 09-12-2004, 12:19 AM
paulcomi's Avatar
Is that plastic material rigid enough to not flex when used as a fence?
paulcomi is offline
post #6 of 22 (permalink) Old 09-12-2004, 01:52 AM Thread Starter
Kevin - They're tee-bolts - just sitting there to illustrate the slots that are cut the full length of the fence - to attach to the aluminum angle fence and for jigs.
post #7 of 22 (permalink) Old 09-12-2004, 12:19 PM Thread Starter
Default More pics on the fence..
I hope they attach...
Name:	openrear2 (Small).jpg
post #8 of 22 (permalink) Old 09-12-2004, 04:45 PM Thread Starter
Paul - The UHMWPE (split) Fence (faces) are attached to an aluminum angle - the real fence. Check out the other pics.
post #9 of 22 (permalink) Old 09-13-2004, 10:33 AM
It is difficult to see from the image what the other end of the bolts are attached to???
2much2soon is offline
post #10 of 22 (permalink) Old 09-16-2004, 06:38 PM
Hi Boomerang; Not sure if I can see all of the picture...but is your table made of that plastic material as well.Looks impressive.I have some of that material I plan on using when I get my plate for my router...............Looks like you may use some big cutters there.Did you try making various inserts of that plastic as well.saw it done before...cuts out a profile of a preferred bit for zero clearance.....LATER,Dave.
rout-on is offline
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Looking for input on home built router table italian biker Table-mounted Routing 10 07-24-2009 09:49 AM
