Hold down. - Router Forums
post #1 of 7 (permalink) Old 06-16-2011, 07:38 PM Thread Starter
First Name: David
Default Hold down.
Hello,
I have a small router table, 2 foot wide.
The other day I was routing a lonb piece of mouling which was bowed a small amount,
I could not keep enough pressure on the stock and feed it at the same time.
Is there a item that I can purchase with a spring loaded wheel that I can install
on my table to help me keep pressure on the stock and be constant on my shape?
I thought about a power feeder , but to big and very costly.
Davie is offline
post #2 of 7 (permalink) Old 06-16-2011, 07:46 PM
First Name: Paul
feather boards work great for your problem.
Dont forget to live life for fear of death grasp each day and live it to it full otherwise it is pointless.
newwoodworker is offline
post #3 of 7 (permalink) Old 06-16-2011, 07:59 PM
Amazon.com: Woodstock W1104 Board Buddies, Yellow: Home Improvement
Amazon.com: buddies hold downs - Tools & Home Improvement
Originally Posted by Davie View Post
Hello,
post #4 of 7 (permalink) Old 06-16-2011, 10:33 PM
Depending on what you are doing to the moulding, you could add a narrow block to the fence on either side of the bit so that the contact area is very small. That way the bow would be contacting only perhaps 4-6" of fence length (i.e. only 1 or 2 inches on either side of the bit). Unless the bow is pretty severe, that length should allow you to do what you need to do.
post #5 of 7 (permalink) Old 06-17-2011, 01:27 AM
Hello,
Hi David - I've got a couple of sets of these. Work great for just that problem.
Amazon.com: Milescraft 1407 D/TFeatherBoard Dual or Tandem FeatherBoards for Router Tables and Table or Band Saws: Home Improvement
Name:	Milescraft featherboards.jpg
John Schaben
jschaben is offline
post #6 of 7 (permalink) Old 06-17-2011, 02:46 PM
I'll pile on with one of the gizmos I use
Woodworker.com: ANTI-KICKBACK HOLD DOWN
TomE is offline
post #7 of 7 (permalink) Old 06-17-2011, 05:04 PM Thread Starter
First Name: David
Thanks,
hey they were all great ideas, didn't think about them for my router.
Like the antikick back rollers, good job.
Davie
Davie is offline
Hold it Down jetvich CNC Routing 15 06-27-2013 02:36 PM
What kind of screws for hold up a plywood sign? bobbotron Starting Off 16 07-13-2011 03:09 PM
Shop Made Vacuum hold down SteveMI CNC Routing 3 06-03-2011 09:15 PM
Vacuum Hold Down Issues bigray222 Table-mounted Routing 2 10-15-2010 05:43 AM
Hold the mice cbsjoez1935 Table-mounted Routing 14 05-03-2007 01:24 AM
