help me - Router Forums
post #1 of 5 (permalink) Old 07-07-2011, 07:39 AM Thread Starter
Country: Chile
Default help me
I need a help please
xD
xD
R1#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - Periodic downloaded static route
Gateway of last resort is not set
C 172.17.0.0/16 is directly connected, Serial0/0
C 192.168.1.0/24 is directly connected, FastEthernet0/0
C 192.168.2.0/24 is directly connected, FastEthernet0/1
R 192.168.3.0/24 [120/1] vía 172.17.0.2, 00:00:17, Serial0/0
R 192.168.4.0/24 [120/1] vía 172.17.0.2, 00:00:17, Serial0/0
b. How Many Networks Routers R1 knows? (1Pt) ________
c. How many networks are directly connected to this Router? (1 Pet) _______
d. How many networks are learned from other routers? (1 Pet )_______
e. Given the codes that appear at the top of the results show ip route, what does "R"? (1 Pet)
__________________________________________________ ____________________________
f. On routes learned through RIP, what device 172.17.0.2 IP address belongs to? (1 Pet)
g. On routes learned through RIP, what device referred Serial0 / 0 mean? (1 Pet)
sykes17 is offline
post #2 of 5 (permalink) Old 07-07-2011, 08:12 AM
papawd's Avatar
First Name: warren
Welcome , this is a woodworking router forum,sorry I cannot help. But maybe someone can help Ya. Good luck
papawd is offline
post #3 of 5 (permalink) Old 07-07-2011, 10:58 AM
MikeMa's Avatar
Here are the steps to correct your issue:
1. Install a 1/4" Spiral Upcut Bit in your plunge router
2. Zero out the depth of the bit by keeping router flat on your bench, and then plunging the bit so it just touches the bit.
3. Set the depth adjustment lever to the desired height.
4. Raise the bit back up
5. Plug the router in , and power it on
6. Using multiple passes make your cut, plunging the bit further and further into the work piece until the depth adjustment stops you
7. Power of the router and unplug
8. Go to your computer and log in to Internet if not already on
9. Open up your favorite browser to Google
10. Enter a search for IP Route and press the Google Search button
11. Pick any of the numerous sites that have the relevant information you are looking for, as you are currently on a woodworking website.
MikeMa is offline
post #4 of 5 (permalink) Old 07-07-2011, 12:41 PM
N'awlins77's Avatar
First Name: Lee
LOL, good one Mike!
N'awlins77 is offline
post #5 of 5 (permalink) Old 07-07-2011, 01:33 PM
First Name: Rob
:d
RobFV is offline
