base plate - Router Forums
post #1 of 4 (permalink) Old 07-21-2011, 07:40 PM Thread Starter
First Name: Bob
Default base plate
I have a set of rockler guides and an old caftsman router plus a handyman router. Fropm what I see I need new base plates to make this work. Is there anything that I need to know to make this work?
bob218
bob218 is offline
post #2 of 4 (permalink) Old 07-21-2011, 08:28 PM
bob218
Hi Bob - Welcome to the forum
I believe sears has a base plate for the Craftsman router that will take guide bushings. I don't know how old your Craftsman is but on some of the older ones, depth setting is an issue.
For the Handyman router, from what I've heard, parts support is an issue with it. This universal baseplate works on most all routers although I have heard some only able to use two of the predrilled holes which isn't really an issue. It also comes with a set of turnlock bushings which swap in and out of the base very quickly. It includes a universal turnlock adapter so you can use your Rockler bushings as well.
Amazon.com: Milescraft 1211 Base Plate Metal-Nose Bushing Set for Routers: Home Improvement
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 07-21-2011, 10:26 PM
G’day Bob
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #4 of 4 (permalink) Old 07-22-2011, 12:37 AM
papawd's Avatar
First Name: warren
Welcome Bob
papawd is offline
Best Base Plate BearLeeAlive Portable Routing 25 08-19-2010 12:41 PM
Router base plate Swallow Table-mounted Routing 30 03-30-2010 01:11 PM
DIY Base Plate and Table bcskinz DIY and Renovation 7 03-25-2010 11:32 AM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 11:37 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 11:15 AM
