Jessem Mast-R-Lift ll-----Ring Inserts ? - Router Forums
post #1 of 7 (permalink) Old 07-25-2011, 09:54 PM Thread Starter
Default Jessem Mast-R-Lift ll-----Ring Inserts ?
I have a Jessem lift 2.
Are Jessems rings / inserts the only game in town?
Seems like Jessem has 4 rings and a 4 ring un-drilled set, only.
Thanks and regards,
Timmberman is offline
post #2 of 7 (permalink) Old 07-26-2011, 08:38 PM Thread Starter
Okay, perhaps I am not saying it right---
I have the Jessem Mast- R-Lift 2 plate that holds the router and moves it up and down.
Jessem provided one red plastic ring to put in the hole in the lift plate
-It locks with a two hole prong spanner
Seems like Incra and a number of others make rings with more various sizes than Jessem. Does anybody know what other manufacturer makes compatible rings?
Regards,
post #3 of 7 (permalink) Old 07-26-2011, 09:05 PM
Regards,
Hi Herb - not that I know of. Those are likely proprietary and unless Jessem licenses someone to mfg the things, no one else can without violating patent rights. I think Jessem does sell blank inserts that you can drill yourself. Issue being that they put the responsibility for getting the hole centered on you. Out of curiousity, do you know if they sell one to accept guide bushings?
The whole insert issue was one of the reasons I elected to go with INCRA for my plate. While their system is also proprietary and difficult to shop reproduce, they offered a wide selection of sizes. They also got premium money but I decided to just bite the bullet and do things right for a change and am very satisfied with the end result.
Did some quick searching. Here's a link for the 4 predrilled sizes they offer:
http://www.jessemdirect.com/product_p/02021.htm
And here's a link for their blank ones:
http://www.jessemdirect.com/SearchRe...p?Search=02028
John Schaben
jschaben is offline
post #4 of 7 (permalink) Old 07-26-2011, 09:52 PM
Hi John
Yes they have one for the PC guides..
02021 Tab-Locā„¢ 4 Piece Insert Ring Set
JessEm Tools Online - www.jessemdirect.com
post #5 of 7 (permalink) Old 07-27-2011, 01:45 PM
JKV
JKV's Avatar
Have you tried e-bay
JKV is offline
post #6 of 7 (permalink) Old 07-27-2011, 06:23 PM
If you get the predrilled set and the blank set you should be "set"
The blank ones come with a predrilled pilot hole so centering a self drill should not be a concern.
TomE is offline
post #7 of 7 (permalink) Old 07-27-2011, 10:25 PM Thread Starter
Default Thanks for the inputs
Forum members,
Again thank you very much for your inputs.
It nice to go to a source of router table information.
I will order both the drilled and un-drilled rings by Jessem.
Regards,
Found: JessEm Rout R Lift Original CapeAtlantic Woodworking Classifieds 2 05-16-2011 02:49 PM
Jessem lift down to $129.99 penaddict Table-mounted Routing 4 09-10-2010 11:48 PM
Jessem RoutR Lift ??????????? hitnailonhead Table-mounted Routing 2 04-10-2008 09:30 AM
Jessem Router lift Versa Incra Precision Router Lift ragman Table-mounted Routing 3 04-01-2006 07:05 PM
