Problems with Oak Park Router Table Top - Router Forums
post #1 of 5 (permalink) Old 09-24-2011, 05:52 AM Thread Starter
First Name: David
Smile Problems with Oak Park Router Table Top
Howdy
I've been using router for 14 yrs and purchased OP table and several jigs in 2000. For the most part I have been happy with these tools but in recent times the templates won't fit the table top opening. I've tried filing the opening but I'm still having problems. I need to waste too much time getting set up due to this problem. Also, the dove tail jig no longer cuts nice neat dove tails. I no longer use it. I hope you can inlighten me.
Dave in Nova Scotia
dcgordon01 is offline
post #2 of 5 (permalink) Old 09-24-2011, 08:38 AM
Hi David, welcome to the forum.
When you say "the template" are you talking about the the router Plate?
Sydney, Australia
jw2170 is offline
post #3 of 5 (permalink) Old 09-26-2011, 05:02 AM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forums, we are glad to have you join us.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 5 (permalink) Old 09-26-2011, 06:09 AM Thread Starter
First Name: David
Howdy James
Yes, I do mean router plate. Thank you
Dave
post #5 of 5 (permalink) Old 09-26-2011, 07:49 AM
kp91's Avatar
First Name: Doug
David,
I have one of my oak park plates that I had to sand a little on one edge because it became too tight that I could hardly get it out of the table sometimes. I don't know if it was just because the plywood has absorbed a little moister and that plate was more snug at the beginning, or some other reason.
As for the problem with the dovetail jig, it could be related to your plate not fitting in nicely. If the plate is not sitting flat and square, you might be misalligned as the jig moves on and off the plate to the table. Try checking that the plate is level with the table using a straight edge.
You may also want to shoot a PM to Rick (http://www.routerforums.com/members/bobandrick-2.html )
for any other ideas, as he's been using the dovetail jig for a long time.
1 John 1:9
Fredericksburg, VA
kp91 is offline
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
New Router Table - Oak Park Style... challagan Table-mounted Routing 21 07-04-2007 07:49 PM
