Collet storage - Router Forums
post #1 of 14 (permalink) Old 10-17-2011, 10:59 PM Thread Starter
Default Collet storage
There are lots of threads about storing your router bits but where do you store your collets? Here is a simple solution that will work with most types of bit storage. Drill holes and glue dowels in them to hold your collets. I removed the 1/4" collet from the dowel for clarity. Do this for all your collets and have them right where you need them. Note: Don't expect the dowels to be the size they claim to be. I had to chuck them up in my drill and sand them to fit.
post #2 of 14 (permalink) Old 10-17-2011, 11:54 PM
Hey Mike - Good tip. I've got a block of MDF with shallow holes to hold the Hex end of things but hadn't thought of a dowel "post" to keep 'em in line.
John Schaben
jschaben is offline
post #3 of 14 (permalink) Old 11-10-2011, 01:21 PM
Thanks for the tip I was looking for a better way nto stor my collet. I am using the plastic baby food containers they work well but still have to be stored.
Thanks Charles
Teach you skill so we don't lose them.
sgmbur is offline
post #4 of 14 (permalink) Old 11-10-2011, 09:28 PM
xplorx4's Avatar
First Name: Jerry
Good plan, now to find time to set all that up, it's out there just need to use it more wisely!!!
Lamentations 3:22-23
xplorx4 is offline
post #5 of 14 (permalink) Old 11-10-2011, 11:24 PM
paduke's Avatar
When I go to buy dowels I take along a block of wood pre drilled for the size I am buying to make sure its really 1/4"
paduke is offline
post #6 of 14 (permalink) Old 11-11-2011, 10:20 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Mike, that is a cool and quick idea - using something non-metallic and still allowing for ventilation (unlike something closed and airtight! Thanks for sharing... OPG3
OPG3 is offline
post #7 of 14 (permalink) Old 12-21-2011, 07:13 PM
The Warthog's Avatar
First Name: Roger
I just keep my other collet in the bit storage section of the box for my router kit. It's always there.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #8 of 14 (permalink) Old 12-23-2011, 04:12 AM
Country: Netherlands
First Name: Gonzalo
Thanks for the tip. Organizing the tools is at times more daunting than the actual woodwork
octaedro7 is offline
post #9 of 14 (permalink) Old 12-23-2011, 05:16 AM
dutchman 46's Avatar
First Name: Howard
Very nice! I will have to do that. For us, who don't have storage! I don't have an excuse, so I guess that it is on My to do list.
John 3:16
dutchman 46 is offline
post #10 of 14 (permalink) Old 03-27-2012, 03:13 PM
mr500's Avatar
Nice . Deff on my DO list
mr500 is offline
Jacob's Power Collet Questions cdevlync General Routing 5 10-20-2010 11:07 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
