Reverse Skies - Router Forums
post #1 of 2 (permalink) Old 11-02-2011, 06:38 AM Thread Starter
Country: Sweden
First Name: Bengt
Default Reverse Skies
Hi
I ended up in a situation where I needed half owel with a precise measure. It will be part of a mold for GRP.
It did not work to split it with a saw, the precision was too poor.
After some thoughts I glued to square pieces on the ends of the dowel. The ends I let the stick out so I had a handle. Then it became easy to mill away half in the table-mounted router. I raised routerbit bit at a time and could measure so that I routed away too much.
/ / LiBah
LiBah is offline
post #2 of 2 (permalink) Old 11-02-2011, 09:11 AM
bobbotron's Avatar
First Name: Rob
Very cool, that sounds like a great way to do it.
bobbotron is offline
Reverse rotation router mach2_man Tools and Woodworking 24 05-23-2019 10:17 AM
Reverse speed possible? paskvale Special Needs Woodworking 6 08-16-2010 01:02 AM
It's safe to look two skies 57 gal turner Show N' Tell 6 06-12-2010 01:58 AM
Reverse Side mit-ch Woodturning and Lathes 4 12-08-2007 12:13 PM
router skies hal Jigs and Fixtures 5 05-30-2007 10:20 PM
