Triton TRC001 Vs. Porter Cable 890 series - Router Forums
post #1 of 30 (permalink) Old 11-05-2011, 10:03 AM Thread Starter
First Name: Jeff
Default Triton TRC001 Vs. Porter Cable 890 series
i'm looking for a router to be strictly in a table, the two most important things i want are above the table height adjustment and bit change. woodcraft has the triton for $199, and the porter cable is $233.....you tube has some nice video's of the triton being used above the table, but i can't find anything on the 890's being used above table.
weedsnager is offline
post #2 of 30 (permalink) Old 11-05-2011, 10:10 AM
Welcome.
I have had a Triton 2-1/4hp mounted in a table & have replaced it with the larger Triton 3-1/4hp router. Both are adjustable from the top. The Triton is an excellent router being mounted in a table. I don't have any experience with the PC890 mounted in a table for comparison. The PC890 is a good router for handheld though. Since this will be a dedicated router for the table & for a little more money, take a look at the Milwaukee 5625-20 3-1/2 Max HP Fixed-Base Production Router. It has some nice features & above table adjustment.
http://www.google.com/products/catal...ed=0CDMQ8wIwAQ
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 30 (permalink) Old 11-05-2011, 10:24 AM
rwl7532's Avatar
First Name: Ralph
I had the same requirement - above the table adjustment.
I went with the Triton 2 1/4 hp.
My table is merely MDF waxed.
(picture taken before Watco and waxing)
rwl7532 is offline
post #4 of 30 (permalink) Old 11-05-2011, 10:28 AM Thread Starter
First Name: Jeff
the above table crank on the triton looks nice, looks like you can crank a bit up and down alot faster with that style of crank, compared to the Pc which has the single knob style .....the triton that im refering to is the 3 1/4 hp version.
post #5 of 30 (permalink) Old 11-05-2011, 10:32 AM
To make bit change easy from above the table. Mount the router in a plate that has easily removable reduction rings (for zero clearance). Remove the ring & with a bent wrench for your router you can change bits without moving router adjustment. Comes in handy when using matching bits as some rail & stile bits are. Putting a rubber grommet in the collet will set your bits at the same height every time without bottoming out the bit.
This style of grommet is firm enough & gives enough movement to allow the collet to grip the bit.
Black 1/2 in. Neoprene Grommet-73578 at The Home Depot
Whittier, CA.
jlord is offline
post #6 of 30 (permalink) Old 11-05-2011, 10:38 AM
Everything is the same on the 3-1/4hp Triton just more powerful .
Whittier, CA.
jlord is offline
post #7 of 30 (permalink) Old 11-05-2011, 01:46 PM Thread Starter
First Name: Jeff
the plate i was gonna use is the woodpecker Phenolic
i really wanted the porter cable, accessories are alot easier to come by, alot of different base options, etc. but the more i read, the more i'm leaning toward the triton
post #8 of 30 (permalink) Old 11-05-2011, 01:56 PM
That plate should will work fine. If it is to be dedicated to be mounted then all the base options wouldn't matter.
Whittier, CA.
jlord is offline
post #9 of 30 (permalink) Old 11-06-2011, 11:08 AM Thread Starter
First Name: Jeff
after more reading , i find alot of people don't like the switch on the triton....the problem with having to tickle it every time you want to do a bit change...i guess if i want 100% i'd have to buy a lift huh?
post #10 of 30 (permalink) Old 11-06-2011, 11:17 AM
Hi Jeff
No need to buy a lift for it, it has one built in and any any time you want to change the bit just push in the lock button in to lock the shaft in place without the need to move the bit up or down..
MLCS Heavyweight and Precision Router Tables
Porter Cable 890 series defective routers Mike Site Help and Suggestions 44 01-16-2011 05:24 AM
Sold: Porter Cable 890 series grip vac handle attachment kp91 Woodworking Classifieds 1 01-27-2010 10:27 PM
Porter Cable vrs Triton angus Table-mounted Routing 22 01-06-2008 11:57 PM
No CD-ROM with Porter Cable 890 Router Combo Kit? Mort_Stevens Table-mounted Routing 11 08-29-2006 12:44 PM
anyone pull the springs out of a Porter Cable 890 plunge base? paulcomi Tools and Woodworking 8 04-23-2006 05:26 PM
