Jointing long pieces - Router Forums
post #1 of 16 (permalink) Old 11-08-2011, 09:06 AM Thread Starter
First Name: Janet
Default Jointing long pieces
I have a small bench top router table, and am finding that when I try to shave the edge off a 5' long piece of redwood, the middle is bowed out a little. Does anyone have an idea why this might be? Or tips on keeping it from happening? I apply pressure on the out feed fence, and my fence is square.
Any ideas or tips are greatly appreciated.
azbird is offline
post #2 of 16 (permalink) Old 11-08-2011, 09:47 AM
The Warthog's Avatar
First Name: Roger
Try attaching a known straight edge along the side of the board, and running the straight edge against a flush trim bit bearing. The board may simply be following its own shape along your table and fence.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #3 of 16 (permalink) Old 11-08-2011, 12:12 PM
dutchman 46's Avatar
First Name: Howard
Hello and welcome! There are a number of things that can cause this! Does the router bit have a bearing on top? It sounds like You are cutting the end grain. What router, table, and bits are You using? Is the slot in the table and the rail of the tool nice and tight,no side play? All these things can help Us give You a better answer, I am sorry, I don't always get the name of the tool I am talking about correct, Memory problem If You can tell us more, Some one brighter than I can give a shot at answering
John 3:16
dutchman 46 is offline
post #4 of 16 (permalink) Old 11-08-2011, 01:04 PM Thread Starter
First Name: Janet
Good tip Roger. I'll give it a go this weekend.
azbird is offline
post #5 of 16 (permalink) Old 11-08-2011, 01:10 PM
First Name: Michael
Ir you are not already doing so, make sure you are using featherboards on both the in and out feed sides. Also you might consider clamping some plywood or MDF aux fences to the table. They can be longer than your existing fence and thus help you control the boards. You may also consider attaching along temp top to the table.
theexpozay is offline
post #6 of 16 (permalink) Old 11-08-2011, 01:12 PM Thread Starter
First Name: Janet
Well, I've tried a straight bit with a bearing on top, and a straight 2 flute bit without a bearing. The grain runs along the length of the board, so I don't *think* I'm in danger of cutting the end grain. Everything appears to be tight, although I'm not exactly sure what you mean by "rail of the tool".
It's a Bosch 1617 router, and the bits are Freud and Whiteside. The router table is a BenchDog Pro Contractor. In spite of not being as far along with my project as I hoped, I'm having a lot of fun and learning tons.
azbird is offline
post #7 of 16 (permalink) Old 11-08-2011, 03:49 PM Thread Starter
First Name: Janet
Being new at this I'm having a hard time envisioning auxiliary fences. Are you talking about clamping something to the table that extends the existing in feed and out feed fences, making them longer, or something altogether different? And by temp top are you talking about extending the existing top to make it larger? I'm already fishing around for something I can use to do that.
Thanks for your help everyone.
azbird is offline
post #8 of 16 (permalink) Old 11-08-2011, 05:51 PM
First Name: Howard
I am glad that You are having fun, and learning. What I was talking about when I mentioned your rail was the miter jig running along the slot meant for it. the gage can some times wiggle in the slot. Sounds like Your doing things as You should. It is possible that the short table is causing Your board to come out with a curve, of imperfection. Hope that explains A little more.
John 3:16
post #9 of 16 (permalink) Old 11-09-2011, 02:20 AM
gav
Country: Croatia
First Name: Gavin
Are you using a jointing fence ? You don't mention that you are, so I would say that's the problem. Your outfeed fence needs to be sticking out 2-3mm more than your infeed side. The outfeed side also needs to be inline with the cutter.
gav is offline
post #10 of 16 (permalink) Old 11-09-2011, 09:54 AM
First Name: Michael
Janet,
You are correct that I meant for you to extend the top and fences. You should be able to simply clamp or bolt a couple feet of MDF or Ply ripped to 5 inches or so to the fence. I would not go much more than 3 feet long on either side as it will become wobbly and heavy.
If you are jointing a lot of material you might consider screwing a 5 " high fence on either side of the bit 90 degrees to a aux base. Drill a hole for the bit to come though the base and clamp the whole jig to the table. Be certain to glue some laminate to the out-feed side of the fence and flush your bearing to the laminate.
The advantage to this is your base can be much longer than you router table as can the fence This will help you control long pieces of material. Again be certain you are using feather boards on both sides of the blade and in front to keep the wood down to the top and against the fence.
How to cut slots in 2 pieces that are not straight on outsides. Midnight Shadow General Routing 4 07-26-2010 11:04 AM
Cut both box joint pieces at once? Fretts Jigs and Fixtures 2 06-15-2010 01:17 PM
Routing small pieces Hamlin Jigs and Fixtures 11 10-25-2009 04:35 PM
Routing small pieces of timber colbra General Routing 11 07-01-2009 06:51 AM
Jointing long boards Jtomwoods Table-mounted Routing 8 05-25-2008 09:05 PM
