New(first) Table build - need advice - Router Forums
post #1 of 7 (permalink) Old 11-09-2011, 06:27 AM Thread Starter
Ash
First Name: prashant
Default New(first) Table build - need advice
Made my first table setup with scraps, and old TV stand, and Jessem lift,fence and top.
I am using my trusty Bosch 1617.
Still very new to the router world.
Few questions:
Any suggestions for a miter fence for this setup?
Does my standard fence need to be parallel to the length (or breadth) of the top or does it not matter much in a router table? If yes is there a quick way to do this?
Thanks!
Ash is offline
post #2 of 7 (permalink) Old 11-09-2011, 09:58 AM
First Name: Michael
your fence only needs to be square to the top in the vertical. Since a router uses a spinning blade the fence does not need to be square in the horizontal.
theexpozay is offline
post #3 of 7 (permalink) Old 11-09-2011, 11:45 AM
Prashant, you do not need a miter slot in your top. Look at the sticky thread about a router sled.
post #4 of 7 (permalink) Old 11-09-2011, 01:26 PM Thread Starter
Ash
Thanks!
Thats what I was assuming, but I wanted to be sure...
Ash is offline
post #5 of 7 (permalink) Old 11-09-2011, 06:50 PM Thread Starter
Ash
I actually already have the miter gauge slot in the top. Just wondering if I should add the gauge?
Can u post a link to the Sled sticky? I could not find it.
Ash is offline
post #6 of 7 (permalink) Old 11-11-2011, 10:27 AM
Oops! I haven't posted it yet Prashant. I will try and get it loaded tonight.
post #7 of 7 (permalink) Old 11-14-2011, 02:03 PM
First Name: Michael
There are many opinions round these parts about what you should do with a fence. Some argue for the bare minimum, a straight piece of wood clamped to the table, others very expensive precisely milled hardware that can be adjusted in a multitude of ways. And everywhere in between. Personally I fall in to the latter. I find t-track on my table and fence useful. I also like to keep things as simple as possible. I like a long tall fence but I often use "sacrificial" wood clamped to my existing fence to achieve this. Ultimately, you will have to make lots of router chips and many many many mistakes to find out what works for you. I suggest starting simple and adding things as you go. I can promise you this, your first router table will not be your last.
Router Table Build (pic heavy) 2bigfeet Table-mounted Routing 42 12-04-2011 10:31 AM
Router table build, Your Experience & Opinions Please Tim Chase Table-mounted Routing 7 06-13-2011 01:39 AM
Advice with table and miter saw purchase 96DGGMWX3 Starting Off 5 04-21-2011 01:26 AM
Router table refurb- Woodpeckers Unilift rstermer Table-mounted Routing 14 11-03-2009 12:21 PM
